LR 2.4 HTA 3586 on E85
I recently had a fray in my signal wire which caused my system to spike. Everything would be fine until about 6000 Rpm then bam straight to the moon. I believe that the frayed wire was giving improper voltage so once it was supposed to reach full current it would freak out because it was not.
stiff *** springs in the wastegate(s) and any decent mbc will kick ***! Ta Ace uses a mbc and he makes good power on a very safe tune. either way you're in good hands.. your car will be a beast.
88%wgdc was 32lbs of boost
90% wgdc was 34lbs of boost spike to 38
92% wgdc was 35lbs spike to 46(this was the first time through when we had the problem)
I did change my wastegate springs from the inital tune to this tune, initial tune we could not get the car to boost over 31lbs of boost(this was with ttp)
I changed to the double blue springs in the tial wastegate, I guess this could be another source of the problem but i am still thinking its the ebc.
O and I hate cars.
O and I hate cars.
agreed this set up is just plain out sick I have never been in anything like it. It is scary fast and spools very quick when you get around 4500 it shoots to the moon. I cant wait to have all the bugs worked out so I can actually enjoy the car or sell it.
Ill try to give you a call tonight just a busy time for me at work if not I have time Friday night. Long story on the selling it this was a project that me and my dad worked on he passed last year all of a sudden so my goal was to just complete it. The cash would be nice to have.
I will be back at awd by the end of the month or sooner depending on the head gasket fix. Part will be here by Monday should be back together by the following weekend.
I do not have up the new graphs from the tune we just did. The tourque is allot higher. This was the graph from the first tune when I had the wrong spring in the wastegate and could not boost over 31lbs.
car makes 700hp almost 600tq and spools by 4600 I think its a pretty good set up.
larger cams and larger intake mani and it would make more but im done after this round.
catch can set up and new head gasket then the final tune and im finished.
