evo 9 stock longblock + fp green hta & E85 | 500hp
Old May 18, 2011 | 01:52 PM
bambooi's Avatar
I think it's tom's tune and the electronic boost control holding boost 32psi over 7k. A lot of people use MBC where the boost falls off. Not many people that post their results on this specific forum use EBC yet.
Old May 18, 2011 | 02:43 PM
project_skyline's Avatar
What smoothing you using?
Old May 18, 2011 | 02:46 PM
bambooi's Avatar
He is using 3. It is in the graph
Old May 18, 2011 | 02:53 PM
getsideways's Avatar
Technically I didnt think an EBC can actually hold more up top then a traditional MBC, Rather it will just create that illusion because the low RPM spike wont be as High.
Sorry for the thread HiJack correct me if im wrong.
Old May 18, 2011 | 03:04 PM
joshl'sevo8's Avatar
You would be surprised what an ebc and a good tune can do for boost uptop.
Old May 18, 2011 | 08:13 PM
I know how to tune to increase boost up top , I would love to see how an EBC allows to hold more up top.
Unless it has to do with lower shaft speeds in the midrange somehow allowing for more up top , maybe someone can PM me about it so i quit derailing this thread as i would be interested to know how that works ha.
Old May 18, 2011 | 08:34 PM
-Evo Aaron-'s Avatar
Great numbers for stock longblock! keep up the good work
Old May 18, 2011 | 11:05 PM
tscompusa2's Avatar
it can and does but there is a point of diminishing returns. more boost doesn't always equal more power. the further you go past the efficiency area of the compressor map the more you increase shaft speeds and heat at the same time. there comes a point where you start losing HP per psi once you reach this pressure limit from the heat increase alone at higher rpm's. i slowly raise the boost and monitor the differences pound for pound.. you cant just throw high boost at these cars without closely monitoring everything thats going on.
theres a balance for everything when tuning, and the tuners most important job is finding that balance to keep the tune safe and the engine healthy.. once you find the perfect balance between everything you will be rewarded with great results in the end everytime.
so to answer your question, yes a 3 port will do more things then a traditional mbc is capable of, but it can also do more harm then good if not tuned properly.
so use with caution and common sense
Old May 19, 2011 | 03:27 AM
Liqquid's Avatar
oh yea! Loved my HTA Green.. be careful with that stock block though that turbo and E85 like to have connecting rods for breakfast
Old May 19, 2011 | 05:40 PM
tscompusa2's Avatar
boost is down to 24-26psi now for the most part.. car is still making close to the 480's hp wise but less tq now. still more power in it, but this is the safer route to go on the stock block since it keeps the torque under control.
wasnt yours making 500wtq+ on a dynojet?
heres where i put him so far
boost plot;
Old May 19, 2011 | 07:49 PM
Liqquid's Avatar
right on. Yea mine was maxed out for what it would do, 35psi on my setup and we didn't do anything to keep the torque down
Old May 19, 2011 | 07:57 PM
tscompusa2's Avatar
lol ya. atleast your dynosheet is showcased on FP's website.
Old May 19, 2011 | 08:00 PM
SEEnoEVO's Avatar
Wow that is insane power!! You have a PM Tom.
Old May 19, 2011 | 09:48 PM
sparky's Avatar
...I would love to see how an EBC allows to hold more up top....
I would like to see the data too! As they say....everyone has an opinion.
Old May 19, 2011 | 11:30 PM
Benja's Avatar
I'm on a 3port.
Peak 26psi finish at 24 psi at 7.5k.
9.8 rear, stock dump, fmic and piping.
