New EVO Red record on BR dyno
Old Jun 3, 2011 | 03:35 PM
David Buschur's Avatar
Curt Brown has once again pulled some tricks out of his sleeve and put together a killer combination of parts.
Curt came in last week with a goal to set the EVO Red record, which was previously held by Tom P/9sec9, and he did it.
The old record was set at 42.5 psi of boost, running VP Import, AEM EMS, high compression 2 liter, BR ported head, Wilson V2.X intake manifold. Tilton clutch, lightweight racing brakes, lightweight wheels/slicks, no exhaust and alky/water injection. With that combination we hit 564 whp.
Curt showed up with his new BR 2.3RPM engine, Curt Brown ported head, Skunk2 Curt ported intake, header, 02 housing, 3" BR turbo back with two mufflers, STOCK ECU on speed density, pump E85 for fuel. FIC2000 injectors, BR double pumper, BR Race FMIC and i/c pipes, S3 cams and the FP Red. The car is nice, he drove here from PA with it for the dyno. Enkei wheels and radial tires. Giro disc rotors and stock calipers.
The tuning began, Curt handles about 99% of it but had a few oddities that were happening and asked me for some help. The car ran EXTREMELY good after the tuning was done, drivability is the best I've seen from stock ECU and speed density after it was done.
We only ran the car up to 37 psi, 5 psi short of what it took to set the old record.
Curt's combination was able to put down 570 whp and 523 ft lbs of torque! The new record is more impressive considering the dyno re-calibration the dyno went through a few years ago that dropped the hp readings and shifted the charts to the right of where they were.
Here's the dyno sheet:
Great job Curt, glad we are friends and thanks for using our parts![/QUOTE]
Old Jun 3, 2011 | 03:46 PM
3grst01's Avatar
wow great job. I bet that thing is a monster on the street. I have decided to go with the red for my 2.4 this is just icing on the cake for my decision.. great job . thanks.
Old Jun 3, 2011 | 04:01 PM
AWD Motorsports's Avatar
Thats a good 25whp over what Most Wanted's Race Car Setup Made!!!!! I already know what Curt is going to run.. LOL Congrats!!!!
Old Jun 3, 2011 | 04:05 PM
red03evo's Avatar
nice, very good #'s
Old Jun 3, 2011 | 04:26 PM
ct9asilver's Avatar
More people need to run that Skunk 2 intake mani it just needs a little work, Curt talked me into using one when i pm'd him about it, and im glad I did it It has a MAP REV 2 port on it! Did he have any results on 93 with this setup?
Old Jun 3, 2011 | 04:38 PM
94AWDcoupe's Avatar
Nice work guys!
can you by chance overlay his green numbers with this??
it looks like driveability takes a big hit. I see torque is 90 down at 3500rpm.
also the power band is not as broad. red hits hard from 6000-8000, green hitting hard 5000-8000
Old Jun 3, 2011 | 04:59 PM
Aby@MIL.SPEC's Avatar
DAMN! Looks Awesome!
Is it possible to plot this against his hta-grn tune that you did a few months back?
so it would be a grn/fpr4 vs red/s3 compare?
was the hta tune on an aem or oem ecu?
Nice work
Old Jun 3, 2011 | 05:07 PM
whtrice's Avatar
Veteran: Air Force
Nice....Torque nice and low...yea baby.....What comp pistons on Curt's 2.3L?
Old Jun 3, 2011 | 05:10 PM
tscompusa2's Avatar
thats good spoolup considering the car has gsc s3's. was this 4th gear also?
not a fair comparison Aby..... the temps were in the 30f's back then.. now it was 75f or so today in ohio. that alone is another 30whp or more for the green + as you said different cams.
his green results were on stock ecu also.
Old Jun 3, 2011 | 07:05 PM
BillSpec's Avatar
Neck Breaker
Old Jun 3, 2011 | 09:31 PM
awddyno's Avatar
Wow! Any mods done to the turbo? That's Beatiful graph.
Old Jun 3, 2011 | 09:40 PM
BigT's Avatar
Great job!
Old Jun 3, 2011 | 09:43 PM
XcreatonX's Avatar
I was already thinking about a 2.3 and a Red and this just gives me more reason to go with it.
Good job
Old Jun 3, 2011 | 10:00 PM
Evoluvin's Avatar
Congrats to CB and to you DB. Was this on the 64mm housing or 80mm?
Old Jun 3, 2011 | 11:12 PM
reed32's Avatar
nice work fellas
