JMFabrication O2 dump results
I had no problem keeping my ewg closed on a td04 wrx with a .9 bar spring. If your wastegate is preloaded properly you shouldn't hear it unless you're above 8 + psi if you don't have a boost controlling device.
Not saying it isn't loud but if a cop hears it in town you prob deserved a ticket for driving obnoxious
ly. Know what I'm gettin at ?
Buuut I totally understand the noise paranoia .. cams no cat, ti exhaust = noise
With a dump the rest of the car can be quieter and the cop wont know it was you when you get off it and cruise by with a stock sounding car. The loud *** 3.5" exhaust with no cats and straight through little muffler car will be pulled over 10x as much.
Its only loud if you are on it above the crack pressure of the wastegate + MBC. For the most part thats 22psi or so and if you are ripping past a cop at 22psi then you probably have more to worry about than how loud you are.
im surprised the poster 10 or so posts up didnt see any gains going from recirc to dumped.
we had a local years ago, test recirc (at a mellow entry angle) v. dumped and gained 50hp w/ it dumped.
im sure modlist, efficiency, how close to being maxed the setup is, etc. play a role, but id expect to see some type of notable gain w/ a dump.
I didn't even know all this talking about me existed!
Aaron, when does it look like you guys will be able to get Johnny's car back on the dyno with the 38mm MVS?
Great cost to benefit ratio here
Mikey
Mikey
Will the 38 MVS really be worth it though?? I guess we'll find out eventually, haven't seen a comparison vs something else...should be interesting.
I have the 44mm MVR on my car. I kind of wish I went 38mm MVS. Externals using both ports will help hold more boost however, the Black is dying pretty hard and Johnny's and my level.
Mikey
Just got my o2 dump on the car last night. All I can say is I am in love. The o2 dump and the FP anti surge cover, makes you car seem like it has a huge aftermarket turbo. The sound just make the car for me. It just make me want to boost everywhere.
Also fantastic product. Build quality is awesome. It looks like a lot of time and effort was put into the design. The only part that I had that rubs a little is my AC line. I just needed to adjust it a little out of the way and all is well. I also have an Aluminum Radiator, and perfect fit with that, no clearance issues.
I will put some pics up tonight or tomorrow.
I wonder if this mod would also help me gain some more power on pump.
Will there be as big of a difference from your (ER) built 2.0 with an Invidia O2 housing to an O2 dump?
-Bink
-Bink
if you dont mind the sound then definitely get the dump.. its well worth it. gains you see depend on your current mods tho. the sound is probably similar anyways with and without.. these cars cant be quiet unless the exhaust is restricted to hell anyways. even my cobb is loud wot and that was supposed to be one of the quietest exhausts on the market
99% of the time an o2 dump always outperforms a standard o2 housing. remember turbo cars don't want any backpressure after the turbo so when you open that exhaust up you get better throttle response, spool, and more power in general most the time.
Whose O2 should I be looking at? MAP / JMFAB / ToxicFab ?
-Bink
I'm all for performance, I was just curious as Collin's O2 housing looks amazing. I'd be surprised if it didn't perform as well.
-Bink
