E85 testing
Old Sep 27, 2011 | 12:28 PM
pug206's Avatar
E85 testing
This is a stock evo IX turbo, stock cams, exhaust 3 "wallbro 255, sparks ikh24, stock injectors and pressure 21.75psi.
The amount of E85 is 75% and 25% 98oct
Graphics with VD.
Sorry for my English...
Old Sep 27, 2011 | 01:47 PM
evo8426's Avatar
Can you change the torque from nm to lb ft on the 2nd graph and remove the 1.22 correction factor?
Old Sep 27, 2011 | 01:55 PM
pug206's Avatar
It's the same launched
In Spain we measure engine power and torque in NM
Delete the second graph?
Old Sep 27, 2011 | 02:00 PM
evo8426's Avatar
Nevermind I see what you did there.
Old Sep 27, 2011 | 03:16 PM
03evo8gsr's Avatar
21.75 boost? if it is , thats kinda low for e85 mix.
Old Sep 27, 2011 | 03:45 PM
MrLith's Avatar
I would be surprised if the stock injectors were keen on much over 21psi, I am honestly quite impressed they allow this much!
Old Sep 27, 2011 | 03:52 PM
deadmeat's Avatar
I'm running 26 psi on stock injectors but I'm sure they are hating life.
Old Sep 27, 2011 | 04:07 PM
Ian0611's Avatar
It doesn't really look like the E85 is helping you since you're still on stock injectors and you're only running 21.57 lbs of boost. You'd probably make more power by running premium gasoline (depending on the octane available to you) and more boost. Either that, or get some larger injectors so you can run more boost with the E85.
Old Sep 27, 2011 | 04:30 PM
pug206's Avatar
Yes, I am a rookie with E85 and want to go slow.
And I have stock injectors, in the red zone missing fuel.
Upload pressure in the middle of rpm
Old Sep 27, 2011 | 04:40 PM
evo8426's Avatar
But are you on e85? It takes quite a bit more fuel to run the same boost as on gasoline
Old Sep 28, 2011 | 02:07 PM
jDOTc's Avatar
jealous of all you guys with easy access to e85...wish they had it in my area
