fp black on stock block and e85
Old Dec 5, 2011 | 11:32 AM
  #31
Boost_Inspired's Avatar
Jorge knows what he is doing and wont tune aggressively unless u practically beg for it lol
Old Dec 5, 2011 | 12:04 PM
  #32
Broham's Avatar
Well I figured he is already at 447 tq, any more without reducing the tq might be kaboom, but if it can stay at 400 or so and just up the whp, it'd be a different story
Old Dec 5, 2011 | 01:10 PM
  #33
lillev23's Avatar
I think he already understands the risk he's taking with his car. People push these motors all the time. I've made almost 530wtq on stock rods and pistons, and I took my motor back down and it was fine. I've seen people blow motors on way less torque then that.
Old Dec 6, 2011 | 03:39 PM
  #34
Evo8jpp's Avatar
Awesome numbers, and so clean of an evo as well...props. OP were you ever on my350?
Old Dec 6, 2011 | 05:04 PM
  #35
fabcas311's Avatar
Thanks!!!yes im a member on there....
Old Dec 6, 2011 | 08:58 PM
  #36
420a-t's Avatar
when people say 400wtq is the limit, is that on a mustang or dynojet? I know its not set in stone, but what is the foundation to this statement?
Thank you
Old Dec 6, 2011 | 10:02 PM
  #37
Levar's Avatar
Veteran: Army
Nothing is documented, my friend. This is merely an unspoken rule and a collective threshold level as it relates to the stock bottom end. All 4G63s react different. From the quote below, you can see this as being fact. When I threw my first rod, I was only making 405wtq on the stock VIII turbo.
For my own peace of mind, I am not going for anything greater than 400wtq until I build the bottom end this time. Lessons learned and applied.
Old Dec 6, 2011 | 10:04 PM
  #38
Levar's Avatar
Veteran: Army
OP: Are you glad that you decided to keep the EVO instead of selling it?
Old Dec 6, 2011 | 10:07 PM
  #39
shattered-4g63's Avatar
I just don't understand the gamble, if you're gonna push 500+ then why not play it safe? Failures at that level can be catastrophic and cost more to repair than if it was built. Awesome stuff though, you got ***** I'll give you that.
Old Dec 6, 2011 | 10:15 PM
  #40
Levar's Avatar
Veteran: Army
Torque is the monster that destroys rods, my friend. Making 500whp can be achieved while keeping torque levels in check through timing variations and other aspects during tuning.
Old Dec 10, 2011 | 12:20 AM
  #41
Yes I understand that but I don't understand the need to make high HP on a stock block? Is it about the money because like I said a failure could cost more.
Old Dec 10, 2011 | 06:18 AM
  #42
Levar's Avatar
Veteran: Army
High horsepower is the not culprit for a destroyed shortblock. Like I said, torque is the monster that results a a rod poking through the shortblock.
Old Dec 11, 2011 | 01:08 AM
  #43
8UpUrV8's Avatar
Can you give some info on the Walbro 400?
Old Dec 11, 2011 | 01:54 AM
  #44
Levar's Avatar
Veteran: Army
I know one of the MAP fellahs is running this same fuel pump. I believe it is Adam. His screen name is: maperformance.
Old Dec 11, 2011 | 10:18 AM
  #45
JDM_MR's Avatar
What rpm are you seeing full boost?
