STM Tuned FP Red + Buschur 2.0LR = Awesome
You can made your own E85...
get ethanol (pure) and mix with gas (premium): 15% gas and 85% ethanol and done!
BTW, nice work!! that car is a beast!!!!!!! With a FP Black that car run 10 flat or 9.9XXX
God.
Start the test window at 2500 RPM's you'll probably see 500 lb/ft by 3600 RPM's. Massive instant torque!
Also, putting this car on a DynoJet will easily net 600WHP which I haven't heard of on a RED with the exception of Most-Wanted's race car.
What a beast!
What a beast!
I think Emery rolls into the throttle at 2k rpm's for all the dyno runs as do I. Obiously with the larger turbos not much happens down that low but this FP Red is very responsive and delivers great power pretty early on. All turbo's have a boost threshold of where the exhuast flow starts to really spool the turbo quickly and getting on the throttle more than 1000 rpm before peak torque probably won't change much. The only time you can get boost earlier is climbing a very steep hill or loading the car down with extra weight where there is more load than it normally sees. It's also why you will see boost earlier in the RPM band when getting on it in taller gears, can also be quite deadly for the engine if you get too aggressive with the tune there.
The graph being set for 1 filter value means every little vibration shows up on the dyno, yet the curve is still quite smooth. I wish the FP Red for the Evo X performed as good but we all know it's not quite the same turbo. Excellent work all around I must say.
Team Blue did work this summer. Local people were not fond of blue Evo's this year and for years to come.
I rode in this car and it is a blast. Spool sounds awesome, and it pulls like a friggen freight train. It's STM'd up, Buschur motored out, has a triple, on AEM with a Tial...uhhhhh I want to touch it. You literally can't help but giggle like a school girl when you ride in it
This kind of build is what does the best kind of advertising for shops... its totally streetable, immaculately clean, makes serious power, and backs up the numbers with on-track performance. I'm not really into the drag thing, but this is a beautifully set up car.
