Andrew's 463whp Auto Evo
Old Sep 22, 2012 | 08:04 AM
  #46
4x4rich89's Avatar
cool car
Originally Posted by JohnBradley
Andrew and I have been hanging out since November 2010 and are the heads of the "R&D" department here at English Racing. We have the wacky ideas, we try them, we have alot we cant use but at the same time we have alot of fun.
Lately of course, EnglishRacing has been hard at work on the Auto project which has been a long time coming. Andrew stepped up the pace when he ordered one last April and decided we were going to make it work. As you know its been in the car since October when we first announced it and we have been working to steadily debug it.
The "Magic Box" has gotten 95% of what we need done so we could test the car.
http://www.youtube.com/watch?v=j5mU4...2&feature=plcp
One thing we learned is that with an auto you sit at the flash point of the converter for a long time. In an Evo on gas or E85 this means it can sit at full timing for several seconds as the converter catches up. Read more about that here (keep in mind it gets a little technical)-
http://www.kennedysdynotune.com/Torq...ter%20Tech.htm
Basically it says as torque goes up so does the flash which is what you will see in the dyno graphs. It looks like late spool but trust me its not, its a mirage of the dyno vs auto.
Andrew has had the same stock motor in his IX as most owners do with some upgrades to make it more fun. In his case it had the following mods-
ER SD tune
GSC S2s
3" turbo back
MAP O2 dump
ER test pipe dump
FIC 1450s
255
64mm FP Red
We started getting a little sketched out by the stock motor and the load it was going to see so even though it had made 401whp through the auto at only 25psi and pumpgas timing on E85, we wanted to fortify it.
This last week, Jeff and TJ did a marathon drop in piston build in an almost while you wait fashion. We changed a few things up in addition to the motor though to help it live in its role as a road race and drag race car-
ER 9:1 2.0L drop in piston motor
84mm Compressor cover
GSC R2 12mm cams (this is the S2R)
GSC Ti retainer/spring combo
Kiggly HLA
Keep in mind this is a stock cylinder head for the time being still, so the results were even cooler than expected-
Pumpgas-
E85-
So the R2s netted us an additional 25whp over the S2s AND spooled faster on a stock cylinder head THRU THE AUTO. We have established with multiple cars with the same basic power level as a manual (mods, boost, fuel, etc.) that we lose 13% through the stock converter. That still means we got around 28whp as a manual. These cams are still not 100% available but will be for the 8 and 9 in the coming months courtesy of GSC. Greg has worked very hard to optimise this profile since we introduced them in Nov 2009. The availability of the billets has been an ongoing problem and that is the main reason there has only been 6-7 sets released. That will be changing in the near future
I am happy to say that the only thing I have seen that beats a GSC cam is another GSC cam-
Pumpgas comparo since we never pushed the E85 tune prior-
Please dont call Greg and ask him when you can get these. When we have a stock of them ready to go, I'll make an announcement. They will definitely need some very specific mods to make them work and at this time they are not meant for a stock motor or anything less than a Red and realistically anything smaller than a Black.
Aaron
Nice #'s
Old Sep 24, 2012 | 06:04 PM
  #47
Downpipe77san's Avatar
Thats just sick!
Old Nov 29, 2012 | 09:37 PM
  #48
R/TErnie's Avatar
Bump for the ER/GSC R2 cams.
I need a set this winter Aaron
Old Dec 1, 2012 | 05:43 AM
  #49
JohnBradley's Avatar
Talked to Greg at dinner about these on Thursday. Still seems to be about the same timeframe. Also talked to Franna yesterday
Old Dec 1, 2012 | 01:50 PM
  #50
R/TErnie's Avatar
nice. they make some hardcore gearsets.
Old Dec 2, 2012 | 11:00 AM
  #51
exhaust_note's Avatar
I am thinking about trying something like this myself in my street car. The stock 5 speed manual trans finally took a complete ****, I need inputshaft, 1st gear,input and output 2nd gears, and input 3rd gear. along with outputbearings, and I have an exedy twin HD I just rebuilt, but it's honestly not going to last that long...I only make 450-475awp thru the 5 speed... I seem to have an idea of what transmission is being used,and I can use the PCS transmission controller....
Old Dec 2, 2012 | 11:05 AM
  #52
jaxx4k's Avatar
now 42psi = 6xxwhp?
Efr8374 - tbd
new weight 2880lbs.
42 p s i ??
Old Dec 2, 2012 | 02:05 PM
  #53
mynx87's Avatar
Nice seems like I know which cams are going in my wife's 8 hopefully they will be readily available by tjr beginning of the year keep up the great work ER
Old Feb 22, 2013 | 12:49 PM
  #54
Migsubishi's Avatar
Bump for higher hp results on ER Auto swap!
Old Feb 22, 2013 | 12:50 PM
  #55
Working on integrating it into the AEM Series 2 right now.
aaron
Old Feb 22, 2013 | 12:53 PM
  #56
Migsubishi's Avatar
aaron
Ut Oh, this gonna be good, I shall stay tuned!!!
JohnBradley
350
Nov 3, 2014 07:07 PM
JohnBradley
Evo X Dyno Results
13
Oct 27, 2013 07:37 PM
JohnBradley
Dec 20, 2012 09:30 AM
JohnBradley
Apr 9, 2012 11:29 AM
JohnBradley
Mar 11, 2012 11:25 AM
