FP HTA 71 w/GSC S2 & Revolver cams! DYNO
Retarding the exhaust cam does exactly dick for power. -3 Intake helps idle and we have found that while peak power doesnt necessarily increase we can get more power at various parts of the powerband.
JR have you verified that this is an HTA71? You bought it new from FP or from someone online? I have the dyno files now so I will compare them. The WB didnt have anything to do with power it was where we were on stock injectors. The other thing to keep in mind is how our dyno is setup for maximum airflow around the car. We have a doorway with a fan, 2 fans in front of the car and 2 fans pulling the air behind the car. I can feel a breeze at the car door. Watching Anthony's video I can see fair amount of EGR action on cars with dumps and THAT DOESNT HELP at all.
Aaron
Aaron
I reread this thread and need to point one thing out, VDR IS NEVER A REPLACEMENT FOR THE REAL THING, EVER.
Between air conditions being less than ideal, the last dyno pulls being done in february during our Ice Age, and then again on a 75* day in a room (as I mentioned) that does not have the same airflow that we do. I agree with Greg, it looks like it needs valvesprings but since Supertech duals also need new valvestem seals my vote is for GSC with Ti retainers
Aaron
Aaron
Aaron I know you don't like vdr but properly done, the values it gives are pretty accurate. After I left the dyno, I came home and went to my tuning road and matched the dyno jet numbers for HP and tq within 5 HP/tq.
Side note I do plan on stopping down there sometime and doing a e-85 tune with you.
Aaron
Aaron
Aaron
Aaron
As for dumps, simply extending the dump back behind the oil pan on a friends drag civic picked up 80WHP on the dyno and leaned the car way out. Going down the track, there is enough airflow that it's probably not an issue with a short dump, but then the tune would be off.
With regards to the VDR comments, I'm sure you get it, but it's worth putting out there. If you use VDR properly, it can be very consistent...TO IT'S SELF. You definitely can't compare to another dyno though and expect the actual number to be the same, just like any other dyno of a different brand comparision. The curve CAN be the same though. One big issue with VDR though is the end of the chart can give you bad data easily. Depending on when the log catches the data and when you let off, it can give high or low numbers very easily.
ReaperX
Feb 16, 2016 05:38 PM
FS[Pacific NW]: Ets high flow cat
jnut24
Oct 1, 2014 09:07 PM
jnut24
Northwest Region
Jun 16, 2011 10:17 PM
