BR tuned, Evo9 Stock turbo...low numbers?
Boost falls of to much at redline.Next time get a hp actuator and a grimmspeed 3 port,you'll hold 24 till redline.Your turbo is not out of steam at that power level and boost levels by the way fyi.
Not bad #s at all! I didn't see anything in this thread about you doing a boost leak test before going to BR or before they put it on the dyno? It's the stock turbo & WGA so boost is gonna drop a decent amount by redline no matter what...
Yes he did a boost leak test he even says that he corrected the trottle body shaft seals and made sure he had a leak free system.
You can also do that with a good mbc and the factory actuator,you don't absolutely need a 3port and an aftermarket actuator to accomplish that,i was holding 24-26 on a similar set up with a Forge mbc and stock Evo 9 actuator when i put down 404.I guess what he meant by out of steam is that the turbo can't keep up with the flow of the engine,something which has been well documented to be true.
98 hp is no joke! I wouldn't complain at all!
Like others have said, his dyno is a heartbreaker. If a final number to brag about is all you're after, go do a pull on a dynojet. You'll be around 330hp, at the very LEAST...
I'm not complaining about my power level, I was asking in reference. Thanks for the confirmations guys
Here's a reference for you. This was my car from the previous owner at Buschurs shop.
Evo 8, stock turbo, stock intercooler, 91oct gas, 21psi.
301hp - 283tq
https://www.evolutionm.net/forums/ev...ur-racing.html
301hp - 283tq
301hp - 283tq
301hp - 283tq
My buddy made 300 or so on an 8 with 10.5 hot side and 272 cams and exhaust on pump gas. Ran 12.7. Not too shabby since your stock cams are basically the same as HKS 272.
How does it feel to you?
