evo 8 stock block 93oct fp red bb speed density .
Spoolup is the same, however once spooled it stays spooled and throttle response is SIGNIFICANTLY improved. I have run both a JB Red and a BB Red and the difference is immense. Could not believe it.
I thought the software automatically updated and/or asked? I guess not, I will look into it. Thanks for the advice both Tom and Jay!
Btw to me the BB version seems a little quieter..however it's marginal.
and i agree with you regarding the throttle response.. thats the biggest plus with the ball bearing. its night and day difference!
1.1.9 is the best dyno simulator there is flat out.. absolutely badass program with no bugs that i can see and i use it everyday.
Best I could do with time and roadspace allotted. Wish I could have started pull earlier but somebody was impatient behind me, it's not perfect anyway as you can see, but only 7hp diff between 1&6 smoothing. Hot and humid as hell here today, sux to work in lol.
Car has 265/35/18 tires hence the tire size diff(marginal) and I had my gf the trusty laptop operator with me as well.
New 1.1.9 software is faster and smoother, me likey! Thanks to you guys for your continued hard work on it and your eagerness to help others, one of the reasons I like this community so much!
looks good but i only share uncorrected numbers. what did it make uncorrected? 460ish?
also no that graph is fine 7hp from 1-6 is perfect! just post it uncorrected without the SAE crap checked.
i think smoothing 3 would best represent this cars power
post that one up with no SAE checked.
good job on the tune.
wanguru.. its mainly because of the tubular manifold giving it the edge uptop and the 3 port holding rock solid boost. the dump helps quite a bit also.
those things will set it apart from the rest. then it has good cams, etc.. numbers are dead on what they should be for this setup.
if its got a 4" intake for the sd thats another 10whp atleast at this boost level on this size turbo.
post that one up with no SAE checked. good job on the tune.
Interesting to note that the intake would help that much....didn't really think it would improve that drastically. It has a 3" on it at the moment.
Thanks for the kind words Tom
I just try to keep the few that I help tune safe.
AMS has a 4" so does JMFAB. i thought STM had a 4" also. i would try swapping to a 4" and see if you pickup some more power.
the number i had in my head from the beginning for this car and its mods was 470 and it looks like you guys nailed it.
maybe it wont pickup anymore power im not sure with a 4" but if you can source one to test it would be worth the test and it shouldn't require any tuning really.
if not, the numbers you got now are good.. so its understandable if you wanna just leave it alone.
wait till it gets colder you will gain a lot more power
