Sd tuning part load vs wastegate tuning
I see a different result when I turn my boost up to 25 and part load the motor at 15 vs tune the wastegate at 15. Is this a difference in ve due to wastegate? Or due to ve changing from part throttle bov venting? Or maybe the condition I'm experiencing is in my head and it's the day to day differences.
Using an o2 dump
Thanks for the thoughts!
Using an o2 dump
Oh crap wrong section meant to go in ecu flash.
Thanks wreckleford I was thinking that map is map. It isn't far but starting off tuning wastegate pressure is how I wanted to prep my high boost setup. I notice that once I turned the boost down I had to retouch my ve map to be richer down low and leaner up top to work with 14-15 wga. Only off about a half point and it seems that there are other factors too
Smooth throttle is my goal so that's why my bov does vent kinda easily at part load ... Greddy type s.
evoterp
Jan 29, 2014 11:32 AM
alcrisulate
Oct 2, 2013 09:34 PM
richardjh
Feb 19, 2011 04:37 PM
jsr426
78
Mar 30, 2009 12:03 PM
