3in exhaust to small for 6765?
Old Aug 22, 2012 | 01:22 PM
turbo speedy's Avatar
Originally Posted by Anarchy99
I read that your car has standard Brian Crower springs without thick seats and not beehives or dual springs. Maybe valve float at that rpm.
i thought the same thing at first but it doesnt seem like like valve float. when i turn the boost down to 28-33psi i the surging goes almost completely away
Old Aug 22, 2012 | 01:25 PM
Blue91lx's Avatar
I'm not trying to flame at all, but did you ever consider the valves floating with the fp5rs and the BC springs/retainers at high rpms?
Old Aug 22, 2012 | 01:34 PM
I thought the same thing but why would the turbo surge if theres valve float? i ran 40psi on my 6262 and never had a surging issue and i was reving the car to 9k
Old Aug 22, 2012 | 01:37 PM
boosted91t's Avatar
Dispose of springs properly
Old Aug 22, 2012 | 03:07 PM
ev0mATT's Avatar
I say just try it and report back with the results!
Every car is different... just because the Supra benefit from the 4" doesn't necessarily mean our cars will too. If you're trying to suck out every last horsepower then try out the 3.5" and see what happens. Try an exhaust with less bends...
Old Aug 22, 2012 | 03:14 PM
JohnBradley's Avatar
Originally Posted by turbo speedy
so your saying by switching to a bigger exhuast i may not only gain hp but it may have faster spool up?
Correct. This has been tested to death by me and others. I know that corking it is never the answer. Just because you "can" run 3" and make 800whp doesnt mean its the best way to go. I know that at 660whp and 26psi I started losing power the more boost I added on my 3.5 when I changed from a straight pipe more or less to a 3.5" Magnaflow muffler. I added a 60mm dump on it and the power came right back.
Old Aug 22, 2012 | 04:29 PM
240Z TwinTurbo's Avatar
After I complete the LS2 coil swap I am going to a 3.5" exhaust starting ~8.0" off the turbo and my ultimate hp goal is 600hp@wheels. Even though it can be done with a 3" exhaust it is a question of efficiency.
A quote from the previous article provided...
While many turbo cars out there use 3-inch exhausts, we've proven that a hefty amount of horses are left in the stable when doing so. In fact, with just the 3.5-inch rear section, 20-whp gains started as low as at the 300-whp level and kept climbing.
Old Aug 23, 2012 | 12:57 AM
giangi's Avatar
As personal experience i can say that, swapping from a 3.5" complete exhaust to a 4" shortest route, on my evo with a BW s400sx 76 mm ( about a gtx45R ), i gained 60 hp and 480 rpm of spool, a surprise for me..... As note, the tuning past 5000 rpm had to be modified a lot, but gains are great, only downside is that a 4" short exhaust is really loud, i don't think it's possible to run it on the road.....
Old Aug 23, 2012 | 08:16 PM
Grimgrak's Avatar
My exhaust setup is going to be the biggest downpipe i can get routed to a Y,which feeds to a stock type silent exhaust and a boost actuated cut out as big as the downpipe.
