TScompTuned 2.4L Built & Tuned FP Black E85 S3s vs Stock cams
Old Sep 21, 2012 | 03:22 PM
5LEEPERISAH23I's Avatar
Originally Posted by badev0
Very nice man. You'll EASILY go 10's You should borrow tom's hoosiers.
I hope i go .04 faster with 60whp more LOL and i want to use his hoosiers but i really feel gripping that well off the start might KO my stock trans. When i go threw the gears now i can tell my stock trans all ready hates me
Originally Posted by cursedsm
Are you still on a stock ported intake mani? I am tring to figure out why Tom makes so much more hp then you. All in all very very nice #'s and I know that things gonna haul ***.
Im on a stock intake mani non ported. id say tom has about 3k-4k more in power mods then me and more boost. yea you really feel the power difference in 4th n 5th when you stop shifting like a go-cart bec the stock gear is stupid short
Originally Posted by Blue91lx
You read my mind. This is a friggin' awesome comparison. Very excited to see how much MPH he picks up at the track.
I dont wanna eat my own words but ill give u my prediction. Shifting into 5th on my $80 all season "420 wear tires LOL" i think i will do 10.8 @ 132-134
Old Sep 21, 2012 | 03:37 PM
Migsubishi's Avatar
Wow nice gain!
Old Sep 21, 2012 | 04:57 PM
CurseDSM's Avatar
Originally Posted by Evoloved
Tom's AMS intake would be my guess as well plus tom has more fuel to work with 2150s' vs 1550's. doesn't Tom also have the stage 3 head from BR?
Originally Posted by tscompusa
his cars on stock head
stock intake manifold
stock throttle body
stock ported exhaust manifold
my car has an AMS f1i intake manifold
Ported head
70mm throttle body
Toxic fab tubular exhaust manifold
no comparison..
the only thing ported on his car is the exhaust manifold.. the rest is 100% stock parts. (his o2 is buschur, his 3" tbe is buschur as well)
Yeah makes since now I was under the impressing that I saw upgraded stuff when I looked at his car at the shootout. Still regardless of stock stuff or not the power is pretty sweet.
Old Sep 21, 2012 | 06:40 PM
04slowevo's Avatar
Are the valve springs/retainers upgraded or are they stock? Just wondering on stage 3 Gsc cams, but I'm assuming they df need the upgraded retainers/springs.
Old Sep 21, 2012 | 08:31 PM
they are upgraded. i have super tech springs / retainers / valves
Old Sep 21, 2012 | 09:23 PM
GotWheelHop's Avatar
Valve springs and retainers are a must with s3's, per GSC.
Old Sep 23, 2012 | 10:47 PM
tscompusa's Avatar
this car has major potential.. it went 11.2 @ 112 letting off (over 104mph in the 1/8) .. he was trying to just qualify only for stock appearing class.. then his next run the cam angle sensor magically died..
i just got back from leak down testing, comp testing, boost leak testing etc.. the car had a massive boost leak at the upper ic piping and his throttle body shaft seals are toasted as well.
but the car we think has a easy 10 in it.. we will update when we get it to Cecil again with my car. i think this things gonna go quicker then my car.
leakdown test was all within 2-4% on a cold engine
comp test was good .. boost leak test it failed horribly lol.
overall visual inspection passed.. so just need to throw in a new
cam angle sensor on the mivec cam side and get it back to the track.
i think i might be putting my old map rev 3 on his car and 65mm tb..
i think after that it will be identical to my car in power if not more.
Old Sep 24, 2012 | 06:23 AM
I'm going to put on the 65mm throttle body for sure. Rev 3 manifold is a maybe At this point I want to get the car running normally before dumping more money into the car. But the CEL says intake side camshaft angle senser n we tested just about everything else that it could be so I'm pretty sure that is the bad. We will no when we get the camshaft angle sensor in the car
Old Sep 24, 2012 | 08:35 AM
wanguru's Avatar
Real nice results. One reason I personally shyed away from 230+ degree cams on a DD has been driveability but this obviously proves otherwise. Good job!
Old Sep 25, 2012 | 10:36 PM
fishpr's Avatar
great numbers
Old Oct 2, 2012 | 12:38 AM
RenEvoIX's Avatar
impressive numbers dude..tscompusa all da way for ma next tune after the build.
Old Oct 2, 2012 | 08:06 AM
maknuge's Avatar
looks like i will be going with gsc s3s. great numbers!
Old Oct 2, 2012 | 11:00 AM
Levar's Avatar
Veteran: Army
Very impressive. GSC S3s making more of a name for themselves even for us typical daily drivers.
Old Oct 2, 2012 | 11:21 AM
R/TErnie's Avatar
great comparison! thanks for sharing.
Old Oct 2, 2012 | 12:25 PM
yea he is the man to go to. ive had 4 different tunes from him, "stock to fully built."
not one issue tune wise.
they are awsome cams!
they ride better then Kelford 272's. they dont buck as much at low speeds i dont how they pulled it off but they did! plus 1 to GSC.
yup no problem
