EFR comparison 8374 vs 7670
Old Sep 27, 2012, 09:08 AM
R/TErnie's Avatar
Geoff's pulls are the Blue ones, mine are in Red.
The big differences between Geoff's and my car is mine is a 2.2L and his is a 2.0L... and I have s3 cams and MIVEC... I believe Geoff has s2's?
Geoff's 8374 .92A/R Divided T4 EFR
Eric's 7670 1.05A/R Divided T4 EFR
Geoff's 2.0L 8374 on 91 pump vs. R/TErnie's 2.2L 7670 on 92 pump
3rd GEAR
Geoff's 2.0L 8374 on Race gas vs. R/TErnie's 2.2L 7670 on E85
3rd GEAR
4th GEAR
Old Sep 27, 2012, 01:23 PM
RJSP's Avatar
Nice comparison, can you comment on your previous FP Red 540 whp setup vs you´re current setup.
Old Sep 27, 2012, 01:42 PM
n2oiroc's Avatar
i think geoff has kelford 272's.
Old Sep 27, 2012, 01:49 PM
R/TErnie's Avatar
If you look in the "break in EFR7670" dyno thread I made I overlay the Red with teh 7670.
I think this is waaaay better. And I haven't turned it up to 40psi like I did with the Red just 25psi on the EFR
Old Sep 27, 2012, 01:56 PM
blackenedwings's Avatar
What boost are you planning to run the EFR on when its all settled in? How is the transient response?
Old Sep 27, 2012, 02:04 PM
R/TErnie's Avatar
Transient is awesome better than the stock 9 Better than my BB HKS7460... better than both of those by a good margin. And makes a ton more power.
Planning on running 40psi peak....and as much as I can past 5500RPM.
Old Sep 27, 2012, 09:59 PM
MrLith's Avatar
Very interested to see how that goes - when will that happen?
Old Sep 27, 2012, 10:07 PM
R/TErnie's Avatar
^ Eh.... planning that hopefully for next week? Like to get it done during the week so i can run the car on the Friday night drags at Mission...with some trick fuel.
Old Sep 27, 2012, 11:11 PM
MrLith's Avatar
Awesome - good luck, and keen to hear how it goes
Old Sep 28, 2012, 04:06 AM
gsrboi80's Avatar
Wow tq at 3500 vs Geoffs is nuts. Both set ups are still awesome none the less.
Sick.
So are these turbos readily available now??
Old Sep 29, 2012, 03:29 PM
Jamison182's Avatar
Very very helpful, thanks for posting this. These are the exact 2 turbos I would love to see tested back to back.
Old Sep 30, 2012, 11:23 AM
maknuge's Avatar
Nice numbers. I am definitely going with one of these turbos. Can't wait to see your high boost numbers.
are you using the top mount internal wastegate manifold like geoff?
Old Sep 30, 2012, 11:42 AM
R/TErnie's Avatar
Mine is a top mount that I made for myself. Twin external MVS gates.
Geoff's has shorter runners (better)
Merge collector (same as mine...but a little shorter length/higher angle)
and he uses smaller diameter runners.
So Geoff's manifold will have better boost threshold than mine.
as far as commercially available manifolds for these turbos.. I REALLY like Geoff's Full-Race top mount setup he made for his own car for the IWG turbos. great manifold
Old Sep 30, 2012, 02:12 PM
maknuge's Avatar
i was looking into the full-race bottom mount. i wonder how the numbers would compare
Old Sep 30, 2012, 02:49 PM
SDevo13's Avatar
Go loot at leetevo's dyno that is the commercially available (bottom mount) full-race set up on a 2.3 (EWG 7670 1.05)
https://www.evolutionm.net/forums/ev...yno-graph.html
Matt H.
Quick Reply: EFR comparison 8374 vs 7670
