TSCOMPTUNED DBB Black, 93 octane
Old Sep 28, 2012 | 04:42 PM
snafufx's Avatar
Yep, another satisfied customer. We talked back and forth for awhile before I decided to try his remote tune and have to admit, I was blown away how meticulous he was to make sure everything was running right. It's been awhile since my car has been 100% and can finally say I'm set. Granted this week wasn't the best time to make pulls with 75-90% humidity due to the rain and temps of 70's, but Tom worked on it. I'll be doing some pulls once the weather finally cools down and sure I'll be in the 500whp club. The spool is crazy on this!!!
The mods that count:
2.3L
stock head
ported/coated stock manifold
S2 cams
DBB FP Black
SD/ECU tune @27psi
Shep trans and tc
1100 Hi-Z injectors
Walbro 255
Spoolinup COP
93 octane
and the rest of the usual mods.
UPDATE:
Planning on going to the track next Sunday and see what it's got and will update the thread with the results and cooler temp dyno. Thanks again!!!!!!
Old Sep 28, 2012 | 07:57 PM
YogSaahoth's Avatar
Veteran: Army
That's one of the faster spooling blacks I've seen. Even for a 2.3 that thing spools up quick. Great powerband. Tom ftw
Old Sep 28, 2012 | 08:07 PM
HsamehH's Avatar
this thing spool quick !!
Old Sep 28, 2012 | 08:35 PM
evo8426's Avatar
Graph looks good but it looks like the air/fuel ratio on there is AFR Map instead of the wideband reading.
Old Sep 28, 2012 | 08:59 PM
jmcmill3's Avatar
def looks like a fun car
Old Sep 28, 2012 | 11:40 PM
boostbxc123's Avatar
Looking good.
Old Sep 29, 2012 | 07:53 AM
sourcelx's Avatar
No cams?
I have similar mods( built 2.0 instead of 2.3l) and hope to get into this power range ( when Tom eventually get to me ). The curve looks awesome! I expect nothing less from Tom. Must be a blast to drive.
-Edwin
Old Sep 29, 2012 | 10:21 AM
High_PSI's Avatar
The smaller the cam the faster the spool. Virtual Dyno? That means it was a street pull? If that is the case the street will load the turbo faster then the dyno especially up a hill.
Old Sep 29, 2012 | 10:55 AM
wanguru's Avatar
Looking good! What cams?
Old Sep 29, 2012 | 11:23 AM
240Z TwinTurbo's Avatar
I didn't see that when comparing my VD with Dynojet results as the spool was essentially unchanged.
Old Sep 29, 2012 | 11:40 AM
snafufx's Avatar
Thanks, sorry I forgot to add, so will edit the list. I'm running S2's. Yeah the spool is definitely quick even though I haven't had a chance to play too much with it. I just wish we had E85 near to see what it could do with that
Old Sep 29, 2012 | 12:27 PM
boostSE's Avatar
That's an amazing power band. Looks fun to drive!
Old Sep 29, 2012 | 12:33 PM
maknuge's Avatar
nice results!
Old Sep 29, 2012 | 03:58 PM
Go_Lancer_Go's Avatar
sweet, this is kinda results i wanna see. I am getting a 2.4 and gonna be doing black on pump. Same cams but w/ tubular. This will give me a good idea on the power ill be hitting.
Old Sep 29, 2012 | 10:35 PM
wanguru's Avatar
This thing ain't no joke. Almost 400wtq at 4500RPM. Looks like a conservative tune also. Good job.
