evo 8 bolt ons 348whp
Old Oct 3, 2012 | 11:56 AM
Dragracer187's Avatar
I just tuned this evo 8 for a friend.
mods:
TBE
750cc
walbro
evo ix turbo
ebay exhaust mani
intake
mbc
24 psi to 22psi 93oct.
Old Oct 3, 2012 | 12:01 PM
evo8426's Avatar
That spools extremely late, boost leak or maybe the turbo is on its way out?
Also that is pretty wavy with a smoothing of 2.
Old Oct 3, 2012 | 01:42 PM
I will do a boostleak test soon and smooth the map a bit, thanks for the input.
Old Oct 3, 2012 | 03:46 PM
emotart's Avatar
+1. I just tuned a car for a buddy with similar mods and he was crossing 300tq right before 3,000RPM...
What kind of timing and AFRs are you running on spool?
Old Oct 4, 2012 | 08:57 AM
300trq before 3000rpm? please post the VD of that chart. This is also a evo 8 with 9 turbo, and more mods. Far off 300trq before 3000rpm, and Mellon is one of the best with stock ecu.
Old Oct 4, 2012 | 09:21 AM
evo8426's Avatar
I have a had charts of my car in the past doing 300tq by 3200. But I rarely drive the car below 3000rpm.
Old Oct 4, 2012 | 10:57 AM
emotart's Avatar
My bad, I hit 3 instead of 4. I meant 4000rpm.
Old Oct 4, 2012 | 11:56 AM
Mellon Racing's Avatar
that's an extremely old chart lol, hence the old business name, not a good representative and on top of that not every car comes here in top form if we didn't do the build. This was a well prepared customer car below: This is a 3rd gear pull, if the pull was done in 4th it would spool up earlier rpm probably.
Old Oct 4, 2012 | 12:12 PM
Thanks for giving your input Mellon, I see I have a long way to go hahaha. You have pm.
Still don't believe you can get 300trq at 3000 or 3200 rpm on a 2.0 stock block evo 8 with evo ix turbo 93 oct, 3rd gear. But please prove me otherwise.
Would you mind posting that VD? was that on a flat road?
Old Oct 4, 2012 | 01:00 PM
evo8426's Avatar
Not on an Evo 8, because I drive a 9. I'm not going to argue about it because I know what it did previously. Starting RPM has a lot to do with it such as starting at 2500 vs 3000 like I always do my logs. I don't have the logs because I delete them once I review and make sure things are ok. Mellon posted a graph above showing a pull starting from 3000 and passing 300tq by 3500. Yes it was on a flat road, I have no to reason to lie to myself when doing my logs.
Old Oct 4, 2012 | 02:11 PM
Corbin09's Avatar
mivec would make a pretty decent difference in spool. This car doesnt have it so that is probably where the discrepancy is coming from with evo8426.
Old Oct 4, 2012 | 08:44 PM
icmanevo's Avatar
My 9 with bolt ons and 91 doesn't hit 300 tq till 4k. Not saying it cant be done. I believe him. I wouldn't want my car to have 300 tqs at 3000. Not easy on the engine.
Evoguy!123
Dec 28, 2016 08:25 AM
alexc
Jun 20, 2016 07:14 PM
Evoguy!123
Apr 22, 2016 06:21 PM
evo8vz
Mar 24, 2016 09:09 PM
Evo11V
Apr 18, 2003 03:07 PM
