Is this VD right?
Old Oct 12, 2012 | 07:32 PM
howell's Avatar
Is this VD right?
I have played with the smoothing and still seems much higher then I feel is right. Road seemed very smooth and very flat.
Attached Thumbnails Is this VD right?-after-tune.jpg   Is this VD right?-after-tune-2.jpg   Is this VD right?-after-tune-3.jpg   Is this VD right?-after-new-tune-3.jpg   Is this VD right?-after-new-tune-4-smoothing-3.jpg
Old Oct 12, 2012 | 07:35 PM
howell's Avatar
The graph with the two logs is my old set up verse my new set up.
I would consider 480-500whp on a dynojet would be exspected compared to the 406whp i did on BR mustang dyno
Old Oct 12, 2012 | 07:36 PM
boosted91t's Avatar
Download version 1.2.0
Get on a nice flat highway, and try a pull. Looks like you are hitting a bump, going up/down a hill or curve.
3rd graph looks the closest, there is also a mustang dyno setting for a comparison to your dyno numbers in your sig
Old Oct 12, 2012 | 07:51 PM
Ian0611's Avatar
If I were a betting man I'd say your clutch is slipping.
Old Oct 12, 2012 | 07:54 PM
boosted91t's Avatar
I hope to god your on E85, or your wideband is seriously off
Old Oct 12, 2012 | 08:06 PM
howell's Avatar
Yeah e85, clutch may be slipping some also. Played with mustang numbers, and was still higher oviously not nearly as high as the Dynojet though.
Old Oct 12, 2012 | 08:09 PM
Boosted Tuning's Avatar
Yeah, def get the new version. Many fixes.
Old Oct 12, 2012 | 08:10 PM
howell's Avatar
Does the vd take ur speed into account, if so a slipping clutch I would imagine it would hurt the power. I know my clutch isn't holding when I launched at import face off last week lol
Old Oct 12, 2012 | 08:11 PM
howell's Avatar
Every time I try to download the new version it fails
Old Oct 12, 2012 | 08:12 PM
boosted91t's Avatar
Please add some fuel, that thing is wayyy lean
Old Oct 12, 2012 | 08:13 PM
boosted91t's Avatar
Time vs RPM plus a few user defined variables
Old Oct 12, 2012 | 08:52 PM
Uninstall all Virtual dyno stuff. The delete all VD folder and such.
Restart computer. Install the newest version. Should work fine then.
Old Oct 12, 2012 | 08:53 PM
Originally Posted by boosted91t
please add some fuel, that thing is wayyy lean
+1
Old Oct 12, 2012 | 09:01 PM
shrtstuff89's Avatar
I agree, needs fuel. Should be seeing more on a black especially on e85. Im seeing that hp on e85 with my green.
Old Oct 12, 2012 | 09:12 PM
howell's Avatar
A/f are prob running lean due to temps being in the high 30s tonight.
Will try to delete and install new version.
Sounds like the high numbers could be a sign of the clutch getting weak
