Evo8 355whp and 349Tq
Quick question also how much can u smooth out the lope on the s2 at idle?and where is your idle usually at with cams 950 rpm or 1k rpm?
i am saying it could be the bov that causing power loss if opens too early i know they are only good up to ard 26 psi.also i will do a boost leak test as well.
I'm sure your tuner did a boost leak test. Did the BOV leak? If so, upgrade. You're putting a lot of money into it, why not get a good BOV? Do you have or plan on a UICP? You can get one with a Tial BOV flange on it and VTA if your SD or recirculate if MAF.
I like to idle S2's at 1100-1200 rpms to smooth it out. Some guys like me to give them more lope so I go down to 950-1000. Timing can affect that too.
I agree with Tom. Lower temps are going to give you more power due to the cold dense air.
i would have thought they would have done done, but i am gonna get it done next wk to make sure no leaks.I am not planning on upgrading the uicp, i was looking into more like the forge RS recirculating where i can just bolt it on thanks.
remember that these cams are pretty big for a stock turbo....im pretty sure when you upgrade to a larger turbo it will really show the difference...
I like my Forge BOV. It never leaked in the 5 years I've had it. I'm using it on my SD set up for the last year and it works as a VTA also if you ever decide to go SD. I'm going to get the Tial or TurboSmart 50mm to see if there is a difference.
I put down a 2.0s 60' ft and still managed to get a 12.55. I think at that time I was putting down less power than you. This was on stock cams stock turbo on E85.
I think your Evo should be faster.
The temp does have a lot do with it, at least it did on my car. On my old setup with BBK-3B/ HKS cams in 93 degree temps my car put down 441 hp/ 395 trq and those were std correction. The uncorrected #'s if I recall were 418 hp but not sure about the torque. I then went there on a nice 35 degree day and put down 466 hp/ 418 trq uncorrected with nothing changed other then the about 60 degree temp difference. So as you can see if you just compare the uncorrected hp #'s theres a +48 hp increase.
.another problem also is we weren't able to up the boost as for some reason car won't go pass 27 psi.We crushed the bov but i think its messed up now.I am looking into getting a proper bov that will hold more boost and perform boost leak test.
My customer with 330WHP in vd dynojet went 12.6 @ 111mph last week.
I do agree with cooler temps, hopefully it makes more on a cooler day as u
Thats odd because I was having the same problem as you, when I had my old FP green swapped for the BBK-3B and then had the car retuned my metal mr bov would not hold boost. When the green was in it would spike 30 and then taper to 24-25, but it wouldn't even go past 27 with the BBK-3B. We try crushing the bov but it didn't do anything, so went with a forge rs and works like a champ.
ok i just installed my forge rs bov today and with some adjustments to the spring back and forth i had to eventually back down boost as i was spiking more than 30 psi now.Before i was not going pass 27 psi, car feels good so hopefully i can take the car to the track soon to see what it does.I guess i can now say my old evox valve was leaking?
