ECUflash and tephra!?!
Old Apr 9, 2013 | 09:27 AM
xtruemassacre's Avatar
Is it possible to run a tuned map of ECUflash and a second map of tephramod V7?
Old Apr 9, 2013 | 10:08 AM
MechTech's Avatar
Read all the stickies and educate yourself a bit more. ECU Flash is a program not a tuned map. Tephra is a modded rom in which you need to tune to your car. Tephra can give you the ability to have multiple maps and change between them. ECU Flash "flashes" tephra v7 to the car.
Old Apr 9, 2013 | 10:12 AM
MechTech's Avatar
Read up:
ECU FLASH: https://www.evolutionm.net/forums/ecuflash-179/
TEPHRA: https://www.evolutionm.net/forums/ec...hramod-v7.html
Old Apr 9, 2013 | 02:27 PM
Thanks. I know this. Im sorry. I must not have been clear in the OP. Is it possible to run the original ROM on one map. And the tephra rom on another??? As opposed to having multiple maps under the same ROM or tephramod.
Old Apr 9, 2013 | 02:39 PM
Raptord's Avatar
No. You'd need to have 2 physical ECU's and switch between the 2...
You can have main maps and alt maps on Tephra though
alsong2002
Jan 8, 2014 05:54 AM
211Ratsbud
Oct 16, 2012 08:19 PM
CRONZ305
Mar 3, 2011 04:02 PM
