Stock Block Evo 9 with minor bolt ons running E85
Well something is amiss. I dont see how a stock cam/stock turbo car would be putting down that much power. If somethings not off with that one then something is wrong with mine lol. Or its a very forgiving dyno.
May need to go over your dyno calibration. Those numbers aren't happening with that mod list sir. If you were local to me I would offer free dyno pulls on my Dynojet just to verify. Maybe there's an FP Red hiding in that turbo cover
An FP red would have maxed the injectors out way before 30psi though.
If it helps the rc1200 were at 97% idc
97% idc in evoscan is roughly 77% or so, it tends to read higher than it should (or at least has in the past).
But ya, its not possible to make the numbers you said on the mods you listed, so i would suggest editing the first post.
Id say its got a green or a bbk or something along those lines if everything else is stock.
RC1200 would not be maxed out on a stock setup. I think you have something like a BBK Full or an FP Green size turbo. Any chance you can get a picture of the turbo?
Where do you see a VD graph posted? I don't see it, I only see where he states those were the numbers he seen on the program.
Im gonna have to echo the same sentiment,
Something isnt quite adding up either in the mods list or
In the calibration of the dyno. I roughly have the same setup on e85 and tuned at 28psi.
Ill pitch in some money to have u send it to another dyno : )
