Stock Block Evo 9 with minor bolt ons running E85
2006 Evo 9
Mishimuto FMIC
Injen Piping
Perrin Intake
RC 1200cc injectors
Full TBE no cats
Stock long block
30 psi
11.6 AFR
E85
Was really surprised at these #'s
On VD dyno jet settings The car put down 453-456 on back to back pulls
Stock Evos dyno around 220-225 whp
Thanks for looking,
Cory
Mishimuto FMIC
Injen Piping
Perrin Intake
RC 1200cc injectors
Full TBE no cats
Stock long block
30 psi
11.6 AFR
E85
Thanks for looking,
Cory
I bet it's a blast to drive with that juicy power band. I have a similar setup with S2 cams and it's a lot of fun. Makes for a well rounded car that's capable of fun in the twisties and in a straight line.
What are you using for boost control?
well if its making those kind of numbers it has mods that he did not list and is not aware of. 450whp~ can't be done with that mod list.
i'm guessing it has something along the lines of:
ported intake manifold
ported tb
ported exhaust manifold
bigger cams (stock cams are not ever going to do 450 on a dynojet on a evo 9 on stock engine)
ported tb
ported tb
ported tb
Actually. The dyno sheet he posted shows 404/424. And if thats on a dynojet thats probably about right. Id say the VD numbers are WAYYYYY off though. Mine has basically the same mods plus kelford 272's, ported exhaust mani, and a megan o2 housing and didnt even crack 400whp on a mustang dyno. Id imagine that would translate to around 430-ish on a dynojet.
The dyno graph is mustang #s. I will see if I can look back to get a vd graph for you. I understand the #'s are higher then usual. Only reason i posted it because it was out of the norm
The car had stock TB, IM, Exh mani and cams
