2.3 6262 93 octane SD
Old Jun 4, 2013 | 01:53 PM
HIS Motorsports's Avatar
I dont get the chance to post a lot of dyno graphs, but I was real happy with this one.
Mods
His Motorsports 2.3 JE pistons, Manley turbo tuff rods
GSC s2 cams
FIC 1450's
Walbro 255 in tank
Hafe manifold with Precision 6262 CEA BB
Full 3 inch Exhaust with test pipe
ETS 3.5 Intercooler kit
Evo X Map sensor Showed 29 psi Throughout the gear.
SAE Correction showed 543 hp and 427 tq
VIDEO
https://www.facebook.com/video/video...58309754259274
Old Jun 4, 2013 | 08:08 PM
batty200's Avatar
Looks like the run was started late. I am particularly interested because I have a 6262 and a Hafe kit and a 2.4 as to when it spools from a low Roll. Say Nail it at 2k in 3rd. What rpm is full boost acheived? Does it spools better or worse than comparable Turbo's on tubular Manifold ? How does power compare?
Old Jun 4, 2013 | 08:15 PM
batty200's Avatar
What compression ratio pistons and is the wastegate recirculated or dumped? I was hoping to be over 600 at 30psi but you are on 93 so i would assume e85 and more optimal timing would add a lot. I have the same cams as well so this is a very close build to mine.
Old Jun 4, 2013 | 08:22 PM
Blue91lx's Avatar
Lol, Batty I was about to drill him with the same questions. I'm thinking we'll spool around 4200 max. This gives me hope!
Stock IM?
Old Jun 4, 2013 | 08:39 PM
batty200's Avatar
Me too! My engine will be assembled this weekend and installed the following weekend barring any unforseen obstacles. I am excited!
Old Jun 4, 2013 | 08:43 PM
okevolutionVIII's Avatar
Just glad to see so many big turbo, Hafe setups popping up and doing some sweet damage on the dyno.
Old Jun 4, 2013 | 08:52 PM
batty200's Avatar
Team Hafe Unite! Hahaha. Ok your car looks a lot like mine. We have all three 62 mm Turbo's of different varieties. I have the crappy turbine wheel I guess. How did your 6152 spool from a low 3rd gear Roll? What is your compression ratio?
Old Jun 4, 2013 | 09:00 PM
ExViTermini's Avatar
I don't think 4200 is anywhere near reasonable sadly. I had a 2.3/35 and it was still 44-4500, and the 6262 seems to be a touch laggier. I had a JB 6262 on a 2.8 bmw engine and with long gears and only 18 psi it hit around 42-4300.
Old Jun 4, 2013 | 10:13 PM
Blue91lx's Avatar
We all (Batty, OK, and I) have cast manifolds and ported stock IMs which both tend to aid a whole bunch in the spool department. I had a 2.0 large runner standard 35r before the 2.4L/Cast Mani 62mm (billet wheels) and it hit full boost around 4500. We shall see, but I surely expect spool to be a decent margin quicker!
Old Jun 5, 2013 | 08:40 AM
The run on the graph was started late, but the car does have stock intake manifold. Boost on another graph showed 20 psi around 4300 and 28 at 4650. The pistons are 8:5 to 1 JE's shelf stock pistons. The car should be back soon for a re-tune with better fuel and possibly a ported intake manifold, where I think we should see 650 to 700 pretty easy! I did think about asking him if I could port the Hafe manifold a little to see if it helped!, but I am a fan of the Hafe now!
Wastegate is dumped!
Old Jun 5, 2013 | 05:59 PM
batty200's Avatar
Very nice! My 10.5:1 should help a little. I have mine port matched but the runners aren't ported. They look nice as is. Excited to see results on better fuel. One more question! What size turbine housing ?
Old Jun 5, 2013 | 07:49 PM
EvoX2NR's Avatar
Nice pump gas results!
Old Jun 5, 2013 | 10:27 PM
tscompusa's Avatar
don't forget mivec. and this car has mivec. around 300RPM more lag for anyone who doesn't have a mivec head.
Old Jun 5, 2013 | 10:32 PM
batty200's Avatar
Dang! I didn't realize this was a 9.
Old Jun 6, 2013 | 06:20 AM
EvoX2NR's Avatar
Tom, is that quickest stock block/ecu title you are claiming just a PB of your customers or just for 2012?
