Evo 8 Fp red DBB 93 oct
Old Jan 31, 2014 | 08:11 PM
  #31
hi2lv's Avatar
You'll be there soon.
Old Feb 1, 2014 | 11:53 AM
  #32
mattyboost's Avatar
I sure hope so.
Old Feb 1, 2014 | 01:05 PM
  #33
94AWDcoupe's Avatar
how much does the car weigh?
Old Feb 1, 2014 | 02:47 PM
  #34
mattyboost's Avatar
around 3400 with me in it
Old Feb 2, 2014 | 02:46 PM
  #35
Bhsj13's Avatar
I am considering the Red. I hear it can hit full 25 psi by 4k rpms?
Old Feb 2, 2014 | 05:26 PM
  #36
mattyboost's Avatar
yup full boost at exactly 4100 and I'm at 25 psi.
Old Feb 2, 2014 | 08:29 PM
  #37
d-bo's Avatar
my car was trapping 127 on 25psi with a 35r .63
what rpm are you finishing your pass in?
post a pic of the slip if you have one
Old Feb 3, 2014 | 08:23 AM
  #38
mattyboost's Avatar
Originally Posted by d-bo
my car was trapping 127 on 25psi with a 35r .63 what rpm are you finishing your pass in? Post a pic of the slip if you have one
Old Feb 3, 2014 | 08:42 AM
  #39
d-bo's Avatar
Looks like whatever happened happened in the 1/8. 60' is pretty decent if you're on street tires.
You still picked up 30mph in the back half which is pretty good and what I'd expect. The 1/8 mph is pretty low
Do you bog super bad off the launch ?
Low 11's should be mid to low 7's et in 1/8
Old Feb 3, 2014 | 02:48 PM
  #40
mattyboost's Avatar
Looks like whatever happened happened in the 1/8. 60' is pretty decent if you're on street tires. You still picked up 30mph in the back half which is pretty good and what I'd expect. The 1/8 mph is pretty low Do you bog super bad off the launch ? Low 11's should be mid to low 7's et in 1/8
yes I'm on street tires and no no bog at all, I did shift about 500 rpm early most of the gears but I wouldn't think that would make a huge difference
Old Feb 3, 2014 | 04:03 PM
  #41
ctfpevoVIII's Avatar
With your power I would of expected low to mid 11's , even your trap at almost 120 mph would indicate a mid to high 11's with a good launch. GLW this upcoming season with your runs.
Old Feb 3, 2014 | 05:01 PM
  #42
mattyboost's Avatar
thanks man, yea hopefully this season I can get a better run.
Old Feb 5, 2014 | 06:42 AM
  #43
dr_latino999's Avatar
Veteran: Army
You should be able to get that better run, I pulled a 12.004@114.3 on a IX Turbo and bolt-ons using the absolutely worse tires for Drag - RS-3's
Old Feb 5, 2014 | 03:35 PM
  #44
mattyboost's Avatar
that's great for a stock turbo. maybe my car wasn't running to the best of it's ability that night , but I did change the plugs immediately beforehand and it wasn't breaking up or anything
Old Feb 5, 2014 | 08:52 PM
  #45
jdmdc2r01's Avatar
How much powe were you making during this 12sec run?
Pump or E85?
