Evo IX 429awhp, 414awtq
Old Aug 1, 2013 | 04:46 PM
FlyingCaveman's Avatar
That's awesome! Makes me sad my 8 makes the same on pump with turbo and cams. The 9 really does work magic with the stock turbo. Does the 9 have the same concern with the 400 ftlbs danger of a stock bottom end?
Old Aug 4, 2013 | 05:50 AM
Ang Wen Yan's Avatar
Yes
Old Aug 6, 2013 | 12:25 PM
evos2k2002's Avatar
Damn that's bad *** for stock turbo and no cams
Old Aug 6, 2013 | 04:57 PM
Skinchin13's Avatar
Sweet. So guys what all do I need to run e85? 1000cc or above injectors? What size fuel pump? And I know it has to get tuned again. What else?
Old Aug 6, 2013 | 07:28 PM
egis's Avatar
You need All parts you mentioned.injectors 1000-1200cc,Wally 255lph and you good to go.
Old Aug 9, 2013 | 03:15 PM
deadmeat's Avatar
Those are the basics but if you're still on a stock motor then I'd recommend checking out an ECU based boost setup. Your tuner will be able to fine tune the torque curve to make things a little less stressful so you don't end up turning your block into swiss cheese.
Old Aug 9, 2013 | 03:38 PM
Pal215's Avatar
This exactly.
I was concerned about the emanent death of my stock bottom end, but when you are controlling boost pressure via load and rpm you get a much safer environment.
I, like most people on evom, liked staying away from the 400 lbtq limit margin, but now I really do believe it's all in the tune.
-pal215
Old Aug 11, 2013 | 04:52 PM
Jerry321's Avatar
Is this much power safe for stock bottom end and drivetrain??
Old Aug 14, 2013 | 12:13 PM
Luis_alexis's Avatar
Nice, I wish we have more e85 pumps near by my area
Old Sep 4, 2013 | 12:01 AM
Pal215's Avatar
Yes, as long as you know how to properly launch ( if you do launch) and there is no dangerous torque spike. The evo's 5 speed is very tough. It's like beef jerky left out in the sun for 10 decades or supermans cape.
-Pal215
Old Oct 25, 2013 | 09:20 PM
evo.matt's Avatar
430hp! that's impressive! How much mpg are you getting with e85?
Old Oct 25, 2013 | 09:42 PM
pcfreakguy's Avatar
Car is a street beast on stock turbo, and e85 . I'm a lil jelly
Old Oct 25, 2013 | 09:46 PM
pcfreakguy's Avatar
-Pal215
The 6 speed transmission in my friends evo 9 mr is a joke. Sometimes when I drive it, and try to put it in reverse. It feels like theirs no option for reverse.
Old Oct 26, 2013 | 05:37 AM
Skinchin13's Avatar
I need your intercooler setup that's what's holding mine back from the 400hp range. I just got my dual map done.
Old Oct 29, 2013 | 05:01 AM
Redliner23's Avatar
-Pal215
LMAO Nice reference. Ive heard nothing but great things about RRE. Got some friends who know scott personally. Wish I was out in Cali to be able to get tuned by them
