TSComp Tuned 2.3L Stroker FP Black 570WHP
Both of these cars went to the track tonight. The FP Black car only was able to go 11.4 @ 126.95 so basically 127 due to the turbo is blown now. It is a journal bearing turbo.
In the video when the turbo was good it was pulling on the 6266 car, so who knows what it would of trapped in full health.
The 6266 car went 130.90 so basically 131. His ET was only 11.6 however.
This car is an animal! Tom you did a great job buddy, I was that extra passenger in there while you were tuning
The changes you made were unreal! I hate to say it but im pretty sure his car will take mine
Glad to see this car finally running right and making tons of JAMM!!
Jared, im excited for our adventures at the track next year!
Glad you stayed focused and determined through all the b.s!
Glad to see this car finally running right and making tons of JAMM!!Jared, im excited for our adventures at the track next year!
Seeing results like this make the decision even harder to make, Tom. I have heard the "FP Black is too expensive for a stock frame turbo" crowd speak loud around here in my part of Texas. "Get the 6262" they scream. I think that for 3/4ths of EVO owners, the FP Black is more than enough turbo (on E85 of course) and these results prove that. I am sure the owner loves the car.
That is promising. Is this a standard 2.3L or the 2.3RPM made by Buschur?
it started off as an AMS 2.3L stroker KIT, now it's just a local build and I continued with the Manley 100mm stroker crank.
I have very crappy luck and like tom said my turbo blew at the track. After every pass my temps shot up to 3/4 but dropped right back down after, do you think this means it's time for a cooling system upgrade? Could this have contributed to my turbo failure? What else could cause my turbo failure? The compressor wheel is grinding on the casing and it's not building boost anymore.
What would everyone recommend I go with for a cooling upgrade?
I cut open the oil filter today and theres no abnormal shavings. Just the normal that I would expect from the first oil change on a freshly rebuilt engine.
Nice job TOM as usual. Now as far as the FP over the PTE thats a hard one. I had a black and moved to a 6266BB turbo and have not regret it at all. Where I trapped 126 with my FP im now trapping 138mph with my PTE and thats with a crappy 1.6 60ft. The PTE seems to pull well into 9500rpm (my shift point) and wants even more. Im only on 30psi and moving to 38 here soon and more timing. Looking for a 145+ trap speep in a full weight car at 3700ft elevation. Im have not been convienced that the FP likes high boost too much after mine failed on me and have read tons of others have also. I love how the FP makes awesome power on pump gas and mid lvl boost but cannot compare with the PTE 62 series on race/E85 and high boost. Just my opinion based on actual experience.
I showed you it i think on msger.
When I had my DBB black i ran 48psi a couple times and no issues (mbc spike). Then set it to 36-37psi across to redline and it lasted and i sold it to my customer and hes running it now with no issues.
I agree. That 6266 car in the video is mine. I originally bought a fp black for my build but then last minute changed my mind and went with the 6266. I will be switching to E85 next season which is where this turbo should shine... Pump gas just does it no justice! Doesn't help that im on a 2.0L
Frew
Nov 23, 2013 11:54 AM
elhuberto
Sep 16, 2013 12:05 PM
darksideauto
Jun 13, 2012 05:36 PM
