Precision 6466 - 837hp/621tq - Strictly Modified
Old Dec 21, 2013 | 03:39 AM
bambooi's Avatar
look at the oil catch can and the crank case pressure!
Old Jan 20, 2014 | 10:07 AM
Strictly Modified's Avatar
Monday bump!
Old Jan 21, 2014 | 07:18 AM
V8HAHA's Avatar
Nice job as usual, I was wondering what Intake mani and throttle body is this setup also what's the weight of the car. What kind of trap speed are you guessing it will produce. Thanks for all the info, I am currently looking at moving from 6266 to 6466 just wanted to get some more info on the turbo.
Old Jan 21, 2014 | 09:43 AM
Thank you! This car is utilizing a Wilson ported IM and Strictly Modified throttle body. I am unsure of the weight of the car, no weight reduction has been done to this car. This car should trap in the 140mph range. It would be a great move on your part to upgrade to a 6466, it wont disappoint!
Old Jan 22, 2014 | 01:47 PM
daplatano91's Avatar
I know you said your running the double pump setup in this monster. Care to say what two pumps are supporting that power on the e70?
Old Jan 22, 2014 | 01:56 PM
Surething, they're Walbro fuel pumps.
Old Jan 22, 2014 | 03:08 PM
Nice to see the 255s being pushed to they're limits.
Old Jan 23, 2014 | 07:12 AM
V8HAHA's Avatar
Thanks for the info, I will be def looking at this turbo if I decide to step up. All I really want is a solid 9sec DD Evo and I already go 140s with my 6266 on 30psi. After this next round of fuel mods be retune to 38psi I'll see where that leaves me but I will be looking the 6466 and Wilson intake mani( I'm on stock) for future mods. Thanks again you guys are the best
Old Jan 26, 2014 | 12:49 AM
IN IDLE's Avatar
Nice!! What head studs and head gasket is used?? And what gearbox/diff set up?? Well done
Old Jan 27, 2014 | 08:08 AM
Thank you! He is using ARP L19 head studs and OEM head gasket. Transmission is rebuilt by Buschur with stock gearing, also the rear end and T-case are stock. The car is stock weight, very pleasant to drive. This is more of a weekend warrior than a race car.
Old Feb 21, 2014 | 11:41 AM
TheCMan's Avatar
Nice build
Old Feb 21, 2014 | 11:47 AM
khmerpimpin's Avatar
Can you share the boost plot? I'd like to compare it to similar setups with strokers.
Old Feb 21, 2014 | 10:25 PM
Grimgrak's Avatar
Turbine housing size? t4?
Old Feb 22, 2014 | 05:24 AM
FL_SilverEvo8's Avatar
To make them numbers(800+ hp) did you upgrade the fuel lines for more volume and also put a fuel pressure regulator? And them wallys you have are they the 255's or are they the new 440's?
Old Feb 24, 2014 | 09:51 AM
MitsubishiJoe's Avatar
It says T3 in the top post!
