Highest Mileage over 500whp?
Old Dec 23, 2013 | 06:09 PM
meckert's Avatar
Originally Posted by GotWheelHop
The extra power is harder on the rod bearings more than anything else. Asking 150k+ mile rod bearings to take that abuse is the X factor in this equation. Doesn't mean they WILL fail, you are just improving the odds of a failure. Hope it lasts for years man.
^^^ you sir are correct..
OP Good luck.
Old Dec 23, 2013 | 06:32 PM
jordanwince's Avatar
OP Good luck.
Thanks bro
Old Dec 23, 2013 | 06:55 PM
surferjeff's Avatar
How much boost?
Old Dec 23, 2013 | 07:11 PM
27 lbs on 93
Old Dec 23, 2013 | 08:30 PM
5speedwtneed's Avatar
the way you drive it is the biggest factor
Old Dec 25, 2013 | 04:29 PM
Its is an every other weekend car, if I even take it out then. And I realy never get into it unless I am getting pestered by another car or taking a friend on a joy ride.
Old Dec 26, 2013 | 08:00 AM
tscompusa's Avatar
ive done some over 500 with almost 160K on them and stock head bolts / gasket seal still. The thing is though, every car is different. one might have been kept stock for all its life, while another one modified a lot, then put back to stock, then sold, then you get it all stock thinking it was never modded, and so forth.
These cars attract people who love to mod cars and usually like to go fast and want a performance based machine, so you have to be careful when deciding what you want to do with a vehicle with high mileage on it.
First thing i would do is a compression test and leakdown test and go from there. if its a healthy engine then id say go for it. (you already did).
It is very true. The way you drive the car plays a huge role in how it holds up also at higher power levels.
Noize
May 14, 2024 07:51 AM
evoyao
Mitsubishi TC-SST Discussion
163
May 26, 2020 12:15 AM
matizzay
Oct 21, 2016 09:40 PM
Redcloud
Jan 25, 2014 03:41 PM
colejack
13
Aug 17, 2004 01:17 PM
