Turbolab of America Stock frame 35R vs Stock turbo 93oct results
#34
I have run this on an X and 8 so far no complaints. Will be running it on my bros 6 soon too.
The 10 has yielded around 490 whp on pump gas at 27 psi and gets full spool at around 4200 RPM.
Has very good quality no need to use exotic high zinc oil which I cant find here locally.
The Evo 8 has done 10 second on stock block and has around 550 whp at 36 PSI nothing on it is ported and is only running cams, 3.5" fmic, intercooler pipes and ect. I really recomend these guys they are very good. Only down side is some times they are hard to get a hold of since its a 2 man shop but its still more personable service than FP or Map. They are quick to reply to emails and will make a custom solution for you.
#36
#37
#40
This is their version of an fp red 58x76 (fp red is 54x76) and Tdo6h4r turbine available in a 9 or 11 blade.
#41
just installed the 7 blade 60x83 turbo from turbolab on my evo. my car isn't tuned yet so no results as of now. i'm on the waiting list for tom to work his magic with my setup hopefully. looking to push the stock block if possible to 550-600whp. i'll keep you guys updated if it makes it or if it vents the block out lol.
#42
#45
