can I get up to 500whp with my set up?
Old Feb 14, 2014 | 08:52 PM
igoiks's Avatar
Got 2003 evo my goal is to get up ti 500whp on E85. I was wondering if anyone has similar set up and what are the numbers. here is the mod list
Wesco pistons 9.0:1
Eagle rods
Bc valve springs and retainers
Tomei 280 cams.
Fic 1450 cc injectors
Walbro 255 fuel pump
Full exhaust
Ported evo 9 turbo.
Old Feb 14, 2014 | 08:59 PM
OhioWhiteEvo8's Avatar
Not 500whp on a real dyno... A 255 pump will only get u to around 400-420 (actual numbers) not inflated dyno jet numbers
Old Feb 14, 2014 | 09:00 PM
TIGERJC's Avatar
Not with the stock turbo. To reach that goal comfortably, you will need to either go FP RED or FP Black or some MAP turbo variety.
Old Feb 14, 2014 | 10:01 PM
rjfg's Avatar
^ this
Old Feb 14, 2014 | 10:20 PM
igoiks's Avatar
So lets say im upgrading to fp black turbo and bigger fuel pump. What numbers can I get?
Old Feb 14, 2014 | 10:41 PM
evo8inlax's Avatar
wont be able to hit the 500hp range on stock turbo go with and FP series turbo
Old Feb 14, 2014 | 11:06 PM
e_kobz's Avatar
With a FP Black and a bigger fuel pump your 500whp should be easy to hit. With other supporting mods you can break into 600whp territory. You should definitely invest in a intercooler and a piping kit as well as an intake (look into speed density). Throw a 02 dump in there as well. Most importantly find a good tuner who can maximize the potential of your car
Old Feb 14, 2014 | 11:33 PM
igoiks's Avatar
I already have ams front, megan o2 dumper, Licp/uicp, 3 port boost controller. The car is on 91 octane right now for brake in but anyways what's the max power on my turbo I was running 430whp before.
Old Feb 15, 2014 | 03:18 AM
vaflyboi757's Avatar
Double pumper and a good sized turbo. Simple and easy.
Old Feb 15, 2014 | 09:19 AM
You'll need cams also..look into a set.of s2
Old Feb 15, 2014 | 10:27 AM
His tomei's should support 500 awhp but the S2's would be a nice upgrade.
Old Feb 15, 2014 | 08:34 PM
JaYr_EvO9's Avatar
Turbo whats going to put you there comfortably like he said !!!!!!
Old Feb 15, 2014 | 09:04 PM
igoiks's Avatar
I was looking at TOMEI 7960 turbo what numbers can I get with it?
Old Feb 16, 2014 | 02:40 AM
You may fall short of your goal with the TOMEI, even with E85. 440-460awhp is my best guess. You may wanna look into the FP and MAP line-ups like mentioned earlier.
Old Feb 16, 2014 | 07:12 AM
e_kobz's Avatar
Send in your Evo 9 turbo to MAP and have them do a EF3 upgrade, that'll put you over the 500whp mark.
http://www.maperformance.com/map-ef3...o-ef3-upg.html
