Evo ix in Australia only making 207hp
Old Mar 18, 2014 | 12:13 AM
troy_ix's Avatar
Hi guys I'm new to evo's. My ix just got tuned today only making a measley 207hp(155kw). It's got a tomei dump and full greddy exhaust. Plazmaman cooler piping and a grimmspeed 3 port boost controller. I'm not entirely happy with the power outcome as I have read stock they make around 225hp(170kw). Any help or recommendations as to why it would only make this sort of power. The tuner said his dyno dynamics dyno always reads low
Old Mar 18, 2014 | 12:41 AM
joseph143's Avatar
Bone stock they make 220... Tuned i made 320... No parts on the car at all just a tune...
If its not breaking up knocking or idling poorly i'd look for a boost leak... And probably a new tuner... Would be the first time i've seen a tuner sand bag a tune to sell your new parts and a retune...
Old Mar 18, 2014 | 03:38 AM
troy_ix's Avatar
This is the dyno graph from the tune, as you can see it spikes at 19 and settles on 17.5.
Old Mar 18, 2014 | 07:48 AM
boost556's Avatar
Originally Posted by troy_ix
Attachment 220767
This I think is the lowest I have seen a pretty much stock evo do especially a 9?
I don't understand why the boost is still at stock 19? Get someone else proper to tune the car turn the boost up a little more and check for boost leaks before retuning make sure there is no leaks from your bov this tends to be overlooked good luck buddy.
I would atleast do an upgraded fuel pump before turning the boost up.
Old Mar 18, 2014 | 11:38 AM
idkmybffjjill's Avatar
Just curious if that tuner has ever done evo's before. Not saying he doesn't know how to tune, just maybe the dyno isn't setup right. I know on our mustang dyno you have to setup a parasitic draw so the dyno knows how much drag the transmision has. This can change your numbers dramatically depending on how it's done. I'd be more worried about how the car runs and feels rather than the number.
Old Mar 18, 2014 | 03:18 PM
troy_ix's Avatar
I asked to goto 22, the tuner told me there was no power difference between 18/22. I have a walbro 255 in it. Don't get me wrong it drives way better then it did. Though the numbers are down
Old Mar 18, 2014 | 03:31 PM
mdsevo06's Avatar
I would look at local boards for other owners with reviews of other tuners, this one does not know how to tune a EVO. There's a huge difference between 18-22psi, you should also take it easy until you find a reputable tuner.
Old Mar 18, 2014 | 03:39 PM
troy_ix's Avatar
Evo's aren't a massive thing in aus like you guys have in the states, ozevo barely gets used as there is not as much interest in them here. So finding a reputable tuner within a decent distance is aus is impossible unfortunately
Old Mar 18, 2014 | 09:12 PM
nursebetty's Avatar
i disagree, every major city has good tuners and a few people do email tunes.
join up to evolutionoz.net will solve all your issues
Old Mar 18, 2014 | 11:15 PM
_evo9's Avatar
i also agree with the above comment..
your new to the evo world mate there is plenty of support, local and the like. plenty of companies still refining parts for the evolution.
OZEVO died years ago evolutionoz.net and also evo squad on Facebook
https://www.facebook.com/BeNchmarkEvolutionSolutions - Look up this guy Mr Benjamin Perry for a tune... He’s able to Flex Fuel Tune your standard ECU that will waken her up
Old Mar 18, 2014 | 11:21 PM
joseph143's Avatar
If nothing else you can always have it email flashed from an american tuner then redyno
Old Mar 19, 2014 | 03:43 PM
troy_ix's Avatar
You're in Sydney are you? I'm on the Gold Coast. There is barely anyone up here that do them, and mercury Motorsport I don't trust because of previous work they've done for me
Old Mar 19, 2014 | 03:44 PM
troy_ix's Avatar
I'm hoping it is just a massive boost leak somewhere. I'll do the test tomorrow and see how I go.
Old Mar 20, 2014 | 12:46 AM
_evo9's Avatar
Actually there is a really good workshop up there Forbidden Performance there in Number: 245 Brisbane rd Gold Coast they have some tough cars under there belt and also built alot of tough cars to..
NA Autosport & Engineering - Neal Lowe very knowledgable workshop entered world time attack last year with a well sorted car.. knows his stuff highly recommended.
2/21 Brennan St - Slacks Creek Queensland.
(07) 3808 3048
for Tuning and performance work you also have Next Up Performance there in Brisbane.
9/115 Dollis St
Rocklea, Queensland.
Hope this helps...
Old Mar 20, 2014 | 01:05 AM
wrx2evoIX's Avatar
You should be seeing at least 210 - 230 KW ATW for those mods with boost of 22 - 24 PSI peak and taper, assuming everything mechanically is OK, your running pump 98 (USA 93) fuel and AFR's in the mid 11's.
I'm in Brisbane, PM me if you want.
