Evo ix in Australia only making 207hp
Actually there is a really good workshop up there Forbidden Performance there in Number: 245 Brisbane rd Gold Coast they have some tough cars under there belt and also built alot of tough cars to..
NA Autosport & Engineering - Neal Lowe very knowledgable workshop entered world time attack last year with a well sorted car.. knows his stuff highly recommended.
2/21 Brennan St - Slacks Creek Queensland.
(07) 3808 3048
for Tuning and performance work you also have Next Up Performance there in Brisbane.
9/115 Dollis St
Rocklea, Queensland.
Hope this helps...
(07) 3808 3048
9/115 Dollis St
Hope this helps...
I would consider doing an etune from a reputable tuner if it's spikes 19 and holding 17.5 it's more than likely not leaking boost.Maybe the dyno us not set up correctly like the other guy said.Run it at a local dragstrip timeslips do not lie.If you're 106 your making more than 206 if that power is correct you will trap 100mph or less.
You're not making any power 'cause you're not making any torque. That looks like a Honda power band. Stock turbo Evos should make all their torque early and taper in the upper range. Its your tune. A mechanical issue wouldn't give you that flat torque curve.
Definately a tuner issue, there is plenty of evo tuners in QLD, just need to do more research, if you want more help join evolutionsquad page on facebook, just send a private message to this link and i will add you in. Post up something there and im sure all the QLD will be able to help you out with tuning etc.
https://www.facebook.com/3voSquad
This is a dyno run at our local Queensland evo owners dyno day. We got one run done before the tuner pulled it from the dyno and said it was to dangerous to keep going. He didn't want to blow it up. It was only there for a power run he had noting to do with the original tune
Hi, I think I am facing a similar issue with an 8. I am getting 127 kw at the rolling road dyno...
I have apexi filter, catback exhaust, and GFB Bov.. After the dyno reading, I went to the mechanic to check for compression and boost leaks....compression was perfect, however they found that the BOV was jammed and it had a split hose (between BOV and intake) due to touching with the fan.....
Do you have an AFR printout with your dyno reading?
Have you checked the spark plugs and BOV to see if they may cause a problem?
Stock ADM Evo 9 makes around 150-160kw atw. Dynos are not that accurate at the end of the day and are more of a tuning tool than anything. I would take it to another place for tuning to get a second opinion.
Hi guys I'm new to evo's. My ix just got tuned today only making a measley 207hp(155kw). It's got a tomei dump and full greddy exhaust. Plazmaman cooler piping and a grimmspeed 3 port boost controller. I'm not entirely happy with the power outcome as I have read stock they make around 225hp(170kw). Any help or recommendations as to why it would only make this sort of power. The tuner said his dyno dynamics dyno always reads low
GoodTimes
17
Jan 27, 2022 06:04 PM
MR1JZ
35
Aug 26, 2016 04:24 PM
