Evo 8 Dyno Results *Air flow issue*
Im running stock evo 9 bov only on 25psi but its holding and im usin a hallman mbc
a way to rule out the mbc; some may consider this risky- but its not if you dont fall asleep, simply remove the line from your w/g actuator.
if you feel boost ramp up hard below 4k in 3rd gear, quickly get off the gas & you know something is up with your mbc.
if it feels the same, swap out the bov for another 1 from a friend.
your car makes boost, it's just slow to ramp up.
Still the same thing went into a tune with a stock turbo and still happening. What else can be causing this. Like i said the only things that were changed prior to this tune was cams, and turbo. But the timing was checked and saod was perfect by 2 diffret shops
[FS] Evo 8 transmission
Migsubishi
Jun 3, 2016 08:13 AM
Evo8urWRX
20
Feb 16, 2003 10:31 PM
