Will Previous Evo Parts fit the EVo 8??
Old Jan 8, 2003 | 07:00 PM
Evo8urWRX's Avatar
Will all aftermarket evo parst for the 6 ,7 etc fit the Evo 8.or will the evo 8 need a whole new line of parts??
Old Jan 8, 2003 | 07:10 PM
Lan Evo's Avatar
I'm guessing you would be able to utilized some engine upgrade from EVO IV (CN9A), EVO V, VI (CP9A), since they share the same engine. However, I would doubt you'll be able to use the suspension parts that designed for them since they have different chassis.
On the otherhand, I think it's highly possible to fit MOST aftermarket parts from the VII to the VIII EXCEPT the parts for the AWD system (ACD/AYC not present on VIII)
Old Jan 9, 2003 | 10:15 PM
Evo8urWRX's Avatar
any more imput.
Old Jan 17, 2003 | 01:14 PM
superGTO's Avatar
Like stated, I believe the EVO 7 will be the most likely to fit. But we all have to take into account what modifications were done to get the U.S. EVO to pass U.S. regulations.
Some things theoretically should fit but might not because of U.S. bumper requirements and engine bay requirements. But any mods at all should be minimal.
I have alot of EVO 4-5-6 parts available, and even though I know they will work for a 7 or 8. Slight modifications are needed to get them to fit right.
Old Jan 22, 2003 | 09:46 AM
rt turbo's Avatar
yeah, i was wondering about this too. will an intake fit? what about a fuel pump. id like to get these things in before a company has to make them. btw, will these simple parts void the warantee? i plan to do much more right away, but im wondering what i have to work with.
Old Jan 23, 2003 | 10:56 PM
Turboniam's Avatar
More than likely ANY mod will void your waranty.
Old Jan 26, 2003 | 06:01 AM
Gary Clark's Avatar
Claudius,
The UK VIII will not have the same drive train as the VII. The ACD and the AYC have been removed and the price is significantly less than the older car.
While it might even make a better road car because of this, it probably signals the end of the rally car for the road.
Watching the Monte last night and their were no Lancers in the top 15 and no factory team present.
Old Jan 26, 2003 | 11:22 PM
erikgj's Avatar
For the Fuel pump go here
http://www.autoperformanceengineering.com/
This is the fuel pump to order (Walbro GSS342 255 l/hr.)
The parts to order are:
FPD006 - $118.65 [ $113 w/ cash discount]
foam sleeve $.53 [$.50 w/ cash discount]
shipping via Priority mail is included
A bag-o-bits is included with the FPD006. It contains a
pickup filter, rubber isolator for the bottom of the pump, and an o-ring for outlet sealing. The FPD006 does not come with the foam
sleeve.
Easiest/quickest way to get it is via the online shopping cart
Ron Gregory
Auto Performance Engineering
2917 Snapdragon Ct
Garland, TX 75040-2833
Old Jan 26, 2003 | 11:39 PM
YellwTyper's Avatar
Sorry off topic.... but lets say I wanted to run 1.5 bar boost, could I go in the direction of the S-AFC, and fuel pump?
Old Jan 27, 2003 | 05:31 PM
YellwTyper's Avatar
Under those circumstances, would reliability play any role, how will the turbo run under those conditions(will life of turbo lifespan diminish?)????
Sorry these are off-topic... but might as well throw em in while we are here.
Old Jan 27, 2003 | 11:47 PM
YellwTyper's Avatar
LOL, well that is a significant amount, but I'm talking about an new E7, not a E8..... Also, if i were to buy a Wide Band 02 sensor(motec most likley) do I have to keep it on the car, or can I just buy it use it when I want to tune the car, and then I can take it off and perhaps use it on my brothers car if he wants to tune his?
What are some other options other then a $1300+USD WB sensor?
