TSComptuned 2.4L (5LEEPER) Evo IX 6466 S3 cams E85
If you wanna make some serious power good luck!
Don't run more then 30 PSI or make more then 525-550whp from my PERSONAL experience.
+1 to that. Ive been running 39-40psi that past few days. Only problem I have now is im maxxing my fuel system out! "non modified 255's"
i feel you. I had to switch to C16 to have enough fuel; too much rush to work out a fuel system. Now after a couple tanks of C16, I realize I could have bought a fuel system for what VP costs these days
We shall see soon! I am swapping my whole setup into a new car and installing a new clutch to hold the power so I can turn it up.
Did you get the fuel system upgraded? Do you still use the stock lines or did you already upgrade?
stock hardlines and stock fuel rail.. I think an aftermarket rail might help a little im not sure tho.
yea anything under 30 PSI your fine, anything over good luck.
Adam arent you stock bore? 86.5mm? Steve is 87mm .020 over. I have some high HP cars with no orings on standard bore with no issues with over 2K+ no issues (using OEM modified HG).
87mm i think for sure needs orings for lots of boost. Sad thing is most the blocks cant clean up good without a .020 over because they are so old and high mileage. Or had failures before.
I think if you switched to a Cometic or cosworth HG you wont have issues since you're on a stock bore.
It seems 87mm is where it gets hairy. Damn I wish mine was a stock bore. I havent had issues yet but i only had 300 miles on it.
Me and Steves are both 87mm bores
I run 35psi on my 2.4L 10:1 built by me on EF4. Only fuel upgrades is Walbro 450 hard wired and 2150cc. I use comedic hg on stock bore and haven't had any issues with pushing coolant.....yet. Lol. Numbers were around 650/540.
