TSComptuned 2.4L (5LEEPER) Evo IX 6466 S3 cams E85
Old Oct 15, 2014 | 12:42 PM
  #76
5LEEPERISAH23I's Avatar
UPDATE: Currently at 1,500 miles running the most boost I've ever ran! "41 PSI" The coolant is not pushing at all. Normally without the O-Ring head it was pushing at 1,100-1,200 miles and getting worse and worse as the miles go up. So the O-Ringed head is DEF WORKING!
Old Oct 15, 2014 | 12:45 PM
  #77
aggieEVO's Avatar
I caught some videos of your car on YouTube last night. Very nice. Be careful!!!
Old Oct 15, 2014 | 03:23 PM
  #78
FameEvo's Avatar
What kind of numbers is it making at 41psi?
Old Oct 15, 2014 | 05:43 PM
  #79
Not to sure. I downloaded the latest VD last week "75 outside" 36 PSI was 715whp. My car every PSI picks up around 10-15whp so id say around 750-760whp on the safe side. I raced a ZR-1 making 780whp with a Weld Drag pack and lost by 1 car. So id say right around 760whp I was making if I had to guess based off previous races with it.
Old Oct 16, 2014 | 07:18 AM
  #80
AreSTG's Avatar
what kind of IDCs are you hitting, if you don't mind me asking? I ruled out E85 on my new turbo, due to being on the BR Double Pumper, and I REALLY doubt it'd keep up over 40psi; until I can install my 044s.
But we have very, very similar setups, so I'm curious how your fuel is doing; maybe I'll give E85 a try on my current fuel system. Did you raise base pressure?
FWIW to you, on C16, my car did not continue to gain loads of power up over 40psi like it did below. Different turbo, and more important different fuel though. I think E85 will be better out the top than C16, and really want to do a direct comparison.
Old Oct 19, 2014 | 12:56 AM
  #81
Id have to check my log but i believe it was right around 83-85% IDC. Im running a BR non modified 255's and FIC 2150cc's stock FPR, 40 PSI in 55-60 degree weather in 4th it was around 12.3-12.5 A/F's
Old Oct 26, 2014 | 03:10 PM
  #82
mitsubeastlee's Avatar
good to know about your fuel setup, im running non modded br double pumper, 2150cc fic, stock fpr with upgraded fuel rail only, oem lines and if your making 750ish VD I think its safe to say you can do 800whp VD all day which is awesome!
Old Oct 27, 2014 | 01:53 PM
  #83
EVOjunky's Avatar
So....... what did you run at EVO vs STI day? I don't think I saw you post it anywhere on FBook.
Old Oct 28, 2014 | 02:26 PM
  #84
yea it should be good for around 800whp depending on weather temp outside.
I bogged "1.96 60ft." and for some reason did a full pass. I ran 11.0 @ 138.6 on top of that sorry time i then had to go to the tower and got kicked out. So to make it even better went to check the log. I forgot to hit the log button on the labtop. On the way home tested it out, was running 35-35.5 psi that run. Pretty much a waste of time and day. Im pretty happy it went 139 pretty much at 35 psi being the fact i was planning on running 40-41 psi.
Old Oct 29, 2014 | 09:59 PM
  #85
AreSTG's Avatar
damn, they are really strict!
Old Oct 30, 2014 | 10:27 AM
  #86
tscompusa's Avatar
They are horrible. I wont ever go there again. I got screamed at last time i went 3 years ago or whenever it was for doing a burnout and going to far down the track.
I also got in a weird groove at that track and it almost put me into the wall. I will stick to my local tracks.
Old Nov 1, 2014 | 04:28 PM
  #87
yea they suck, ill never take my car there again.
Old Nov 1, 2014 | 05:10 PM
  #88
apagan01's Avatar
Car is bucking
Old Nov 12, 2014 | 08:09 AM
  #89
Originally Posted by apagan01
Car is bucking
huh? If you saw the video, i think that is what your talking about. Yes it bucked down to 3k ish then had to re-spool to get going ha!
Old Nov 12, 2014 | 07:37 PM
  #90
tscompusa's Avatar
HAHAHA.
That's not what he meant. He meant the car is bucking, as in its moving. Its just another way of saying its fast. He was complimenting it.
