evo 9 stock turbo/block 36psi s2 e85 makes how much??
Old May 1, 2014 | 06:30 PM
prowakeskater's Avatar
Question evo 9 stock turbo/block 36psi s2 e85 makes how much??
this cannot be right, right?
I did a 4th gear pull after richening some areas that were getting up to 13 AFR
still trying to bring things down to 12 flat, sometimes some pulls gets up to 12.8 still. Almost wondering if I'm starting to run out of fuel... no way though, right?
I am holding 28psi at 6k...
but this has to be wrong. To this date, virtual dyno has been very accurate for me.
whats going on here? does my stock block/turbo really make just under 470hp in 4th?
Old May 1, 2014 | 07:28 PM
dtrackstar's Avatar
I'm no expert on VDs. But 36psi on stock block isn't going to last long
Old May 1, 2014 | 08:16 PM
AWD96's Avatar
36psi on stock turbo/motor usually makes a new window, or 2 if you know what your doing.
Why would you be doing 4th gear pulls anyways? On a stock motor and VD none the less. Especially with the load/tq hit your asking for it. If you can't get it dialed in in 3rd it might be time to get alittle help from someone.
FWIW 4th gear always makes more also. Even in virtual land.
Old May 1, 2014 | 10:48 PM
TheBoz's Avatar
Yes those numbers can be very correct, and yes you sure can window your block.
Here is what my car made on 28-29psi on e85 (452/449) it went 11.7 @ 119
https://www.evolutionm.net/forums/at...9-turbo-dj.jpg
Old May 2, 2014 | 08:41 AM
wuh oh. looks like ill be taking advantage of some gear based boost control
Old May 2, 2014 | 10:04 AM
boost556's Avatar
those # should have run very low 11's no?
Old May 2, 2014 | 10:44 AM
04slowevo's Avatar
I can see number being right, but motor will have a window soon if ran hard. I was at close to 450/440 33psi and it had a window in it in January.
Old May 2, 2014 | 11:33 AM
egis's Avatar
So 470 is not enough?same parts I made 360 on mustang at 27psi.
Old May 2, 2014 | 12:29 PM
slowsrt4:('s Avatar
much boost, such blow
Old May 2, 2014 | 03:11 PM
Bhsj13's Avatar
36 on a stock turbo. lets see how long that turbo lasts you.
Old May 2, 2014 | 05:44 PM
tscompusa's Avatar
470WHP should trap about 125 in full weight (3400lb).
Post that same graph with smoothing 1. I'm curious what it looks like.
Add:
Also guys Ryan always does this with his personal cars. Tunes them on the edge lol.
Old May 2, 2014 | 06:26 PM
slowsrt4:('s Avatar
all of this power on a single walboro?
Old May 2, 2014 | 07:17 PM
tscompusa's Avatar
Its modded so it can handle about 480WHP modded (depending on health of fuel system & AFR, some can do about 500ish. (I did a lot of before & after comparisons on here with walbro 255's if you dig for the testing) even at 75psi fuel pressure (30psi+ boost on stock regulator) (Bigger injectors may up the number alittle also)
Keep in mind the boost falls off also on a stock turbo. so his total fuel pressure is not that high, which makes the walbro 255 that much more efficient at its job.
Id be more concerned about the crossover downlow with AFR at 3700RPM its 13 AFR with 22psi. that is not what you want. needs to be richer.
I dont know about the numbers so I'm not going to say anything. but lets just say a 420WHP car should trap 120-121 in the 1/4 with ease. (full weight).
Old May 2, 2014 | 09:13 PM
wreckleford's Avatar
Is this really any riskier than for example the 570 plus fp black stock block car a couple threads down?
Old May 2, 2014 | 10:55 PM
tscompusa's Avatar
no
