BOOSTED TUNING Custom Remote Tune - EVO 9/EF 2.5 on 91oct and E85
Old Jun 19, 2014 | 11:07 AM
Boosted Tuning's Avatar
Evo IX
MAP EF 2.5 Turbo
Greddy Easy Cams
FIC 1050s
3" TBE
Tuned this car for a long time client. Made good power on 91oct and E85. 91oct tuned was left conservative, as the client tracks this car. We turned the boost up a lil more on E85, and made about 495ish, but the AFRs went to lean because the single pump couldn't hang.
Attached Thumbnails BOOSTED TUNING Custom Remote Tune - EVO 9/EF 2.5 on 91oct and E85-jason-ef-2.5-91oct-dyno.jpg   BOOSTED TUNING Custom Remote Tune - EVO 9/EF 2.5 on 91oct and E85-jason-ef2.5-e85-dyno.jpg
Old Jun 19, 2014 | 04:18 PM
desiromeo812's Avatar
Loooks good. How much boost on the 91 map?
Old Jun 19, 2014 | 04:37 PM
I believe like 25 taping to 23ish.
Old Jun 24, 2014 | 07:06 AM
mrfred's Avatar
nice job.
Old Jun 24, 2014 | 01:44 PM
slowsrt4:('s Avatar
good numbers for the map EF 2.5
Old Jun 24, 2014 | 06:50 PM
oscarquinones's Avatar
nice numbers
Old Jun 25, 2014 | 06:20 AM
charlie.tunah's Avatar
looks great!
How do the "easy cams" compare to S2s?
Old Jun 25, 2014 | 06:30 AM
heel2toe's Avatar
I love the shape of those graphs! Look how flat the tq is between 4500 and 7000 And the power just keeps going and going, that's awesome!
The e85 run looks like it hit 28#, correct? Which wastegate is on the turbo?
Tunah- The Greddy easy cams are pretty mild. IIRC they are pretty comparable to HKS272's. The S2's should make more power mid and up top but may give up a little down low.
Old Jun 25, 2014 | 06:33 AM
Gotcha. Im hoping to break 400 without much effort (on 91). Assuming I can get the tune dialed in, this supports that goal. So far, at 4 psi less, Ive lost nothing down low.
Old Jun 25, 2014 | 06:36 AM
Jay,
Was the shape of the spool up on 91 about the same as the E85? 20psi @ 3750?
Old Jun 25, 2014 | 06:49 AM
heel2toe's Avatar
You just swapped in S2's paired with an HTA71, correct?
I'm still getting my tune dialed in as I swapped out my HKS 272's in favor S2's a few weeks back. I didnt notice any loss down low but my butt dyno may need to be re calibrated.
I'm just trying to figure out how to get my charts to have a similar shape. I'm out of WGDC so I think my wastegate for my BBK Full is holding me back.
Im guessing this was tuned with a 3-port but Im curious as to which wastegate was used?
Old Jun 25, 2014 | 06:58 AM
ihockey1's Avatar
If I had to guess I'd say its the turbosmart iwg Map puts on the turbos they build
Old Jun 25, 2014 | 11:23 PM
asu11's Avatar
stock block?
Old Jun 29, 2014 | 09:19 AM
S2s are way bigger then the Easy Cams
Dont have boost data for the 91oct tune, but it made 390ish, with 25psi tapering to 22-23 (read via gauge by client)
Car had a MBC on it, but we are now retuning it for a 3port, to help with the map switching.
And yes, this car is stock block. And one of the cylinders is low on compression. Client is building the motor soon.
Boosted Tuning
Jan 21, 2014 09:31 AM
impulseracing01
Nov 21, 2011 01:25 PM
Boosted Tuning
Oct 6, 2011 07:22 PM
ArchieBabes
Aug 18, 2010 09:24 AM
vegasboy301
Jul 11, 2006 01:14 AM
