Evo IX, FP Red, 93oct, 425/359.
Old Jun 20, 2014 | 06:39 AM
misterchonger's Avatar
Hey everyone. I bought this car late last year and tuned it this past Feb. Just now getting around to posting the VD graph. Let me know what you guys think.
FP Red 80mm (JB? -Came with the car)
PPI Coated/Ported Exhaust Manifold
Ported Megan o2 Housing
GSC S1 Cams
FIC 880cc Injectors
Walbro 255
ETS 3.5" FMIC w/ Piping
Custom TBE - AMS DP, HFC, Magnaflow Resonator, and Dynomax Superturbo 3'' Muffler (quiets it down pretty good)
Tephra v7/MAF
26psi, MBC
Old Jun 20, 2014 | 08:46 AM
gmac03's Avatar
That looks very nice!
Old Jun 20, 2014 | 08:50 AM
Thank you sir!
Old Jun 20, 2014 | 08:55 AM
ronaldo9's Avatar
Love the set up I hope to complete something similar to that one day. How is it driving around town?
Old Jun 20, 2014 | 09:04 AM
tscompusa's Avatar
I was gonna say the AFR curve looks good. maybe richen it a bit at 100 load to get it closer to a 12.8-13 AFR on spool. other then that it looks good.
You should be posting a recent graph with summer temps though and not one from cold February to ask about power levels.
Its not gonna make the same power now in this heat as it did then. So when asking for power judgements its not really relevant to this current time.
About for every 1 degree you lose 1whp something close to that.
Old Jun 20, 2014 | 09:06 AM
tscompusa's Avatar
Also dont trust VD correction factor always run it uncorrected in its normal state.
and throw some GSC S2 in there. more power easily for you.
Old Jun 20, 2014 | 09:34 AM
Thanks man. It drives ok around town. I feel like the low compression with the larger turbo makes it a little less enjoyable than it could be with a smaller turbo around town. I feel like I have to wind it up a bit to get moving.
Last tank average was 28 mpg but it was mostly highway.
Could a stroker setup with this turbo be the best of both worlds?
Old Jun 20, 2014 | 09:38 AM
Ahhh, good to know! I'll try to grab a recent one and post it. Thanks for chiming in, I follow your posts/threads and appreciate all the information you share!
Again, thanks for the heads up! Won't the S2's move the power band further up? If so, I'd like to keep it more towards the midrange. This car will most likely not see very much track time. But a lot of autox time.
Old Jun 20, 2014 | 09:43 AM
tscompusa's Avatar
You wont really notice a difference from the S1 and S2 honestly. Now the S3 will lag you noticeably with that turbo.
No problem at all.
I don't think i have any s1 vs s2 comparisons on a red with the same customers car, but if the car is only focusing on lower RPM then i suppose its not worth the cam swap if you are not interested in top end.
Old Jun 20, 2014 | 09:49 AM
No problem at all.
Ah, gotcha. Good to know. Thank you!
Old Jun 20, 2014 | 01:21 PM
Bhsj13's Avatar
look at that broad torque curve.
Old Jun 20, 2014 | 01:39 PM
Old Jun 22, 2014 | 11:21 AM
ZNS3's Avatar
Looks good .
Old Jun 22, 2014 | 01:46 PM
slowsrt4:('s Avatar
good numbers man, gotta love the FP Red
Old Jun 22, 2014 | 01:49 PM
High_PSI's Avatar
Good numbers and nice and safe
