uvambo's 2.4L EFR 8374 - getting ready for roll racing
Old Aug 27, 2014 | 11:45 PM
mrfred's Avatar
There's a big roll race happening in the Seattle area this weekend, so Martin had me bump up the power a bit. The tune is all Aaron@ER's handy work. I just increased boost by a few PSI, and since it was showing 12-12.2:1 AFRs at some spots at the start of the session, I richened AFRs to 11.4-11.7:1 to help keep heat buildup under control. These are the final two pulls. Logged AFRs are about 0.3 pts leaner than on the AEM gauge. I totally dig this setup - 500+ ft-lbs from 5000-7000 rpm, great power from 4500-8300 rpm, and awesome transient response. And it did all this with no more than 34 psi of boost.
UPDATE: As I was looking over the VD plots, I realized that the wrong total vehicle weight was being used. Here is the updated plot. Peak power is now closer to 750 whp according to VD. However, this is not consistent with what it did on ER's dyno jet. I seem to recall it made 743 whp but at higher boost. At any rate, it is a VD plot. Road was very slightly uphill, and there was a light crosswind.
Attached Thumbnails uvambo's 2.4L EFR 8374 - getting ready for roll racing-martin_final_20140827.gif
Old Aug 27, 2014 | 11:51 PM
DsmGuy86's Avatar
That looks like a fun ride. I was trying to go to this but don't think the cars gonna be ready in time. Good luck buddy.
Old Aug 28, 2014 | 05:30 AM
94AWDcoupe's Avatar
wish I could attend with my little evo that could
Old Aug 28, 2014 | 08:56 AM
black E's Avatar
Is this IWG or EWG?
I ask because I'm having trouble holding even 30psi to 9k rpm on my IWG 8374 setup.
Can you also post the relevant mod list? Thx
Old Aug 28, 2014 | 09:21 AM
uvambo's Avatar
Thanks again Mychailo .
Black E
It's external gates, two twin mvr's.
It's a very modified Full race kit mostly for fitment. Mods that matter 2.4LR, GSC R2 cams, 8374 (1.05ar), 2150 FIC, ER ported head. Also this is through two mufflers
Old Aug 28, 2014 | 10:17 AM
black E's Avatar
Yeah I almost regret going with the IWG on my X but I love not having the EWG dump noise.
Mine is making ~650 WHP on a 2.0 at 30psi and I get from what I can tell slighty better response then you, full boost by ~42-4300 rpm.
Congrats, def a killer setup for the street!
Oh BTW, is this on pump,e85?
Old Aug 28, 2014 | 10:36 AM
uvambo's Avatar
thanks black E. Yea on E-77 to be exact.
Old Aug 28, 2014 | 12:45 PM
AreSTG's Avatar
You can recirculate an external wastegate
Old Aug 28, 2014 | 01:50 PM
black E's Avatar
You can but in a Evo X is much easier said then done, there's just not that much room to play back there. You would have to take the motor out to install the DP/wastegate tubes properly.
Old Aug 28, 2014 | 05:16 PM
tscompusa's Avatar
4K area needs a ton of work. 13 afr with 20psi~.
Old Aug 28, 2014 | 05:24 PM
Grimgrak's Avatar
How is transient response compared to your old setup gt3076 would your current setup give up anything in a road race situation?
Old Aug 28, 2014 | 05:58 PM
mrfred's Avatar
As I mentioned, the AEM gauge was reading 0.3 pts richer than the logs, and the log shows about 12.8:1 at 4000 rpm, so actual is about 12.5:1. The car felt great in that rpm range, and knock voltage looked good in that range as well. You are right though, it should be dropped down to around 12.0.
Old Aug 28, 2014 | 06:07 PM
tscompusa's Avatar
Ya id drop it around 11.5-12 but that is up to you. Its not going to hurt anything as is though since its E85.
just giving you ****.
Old Aug 28, 2014 | 06:13 PM
mrfred's Avatar
I should have paid more attention to that area, so bring it on.
On a side note, his setup is so fun. Responsiveness is amazing.
Old Aug 28, 2014 | 06:23 PM
tscompusa's Avatar
Ya it looks like my 2.4 6466 low RPM. I would like to overlay it actually. My car is a little different though, but they both have advantages.
If you don't mind send me over a run to tom@tscomptuned.net i will post the overlay when i loaded my car up early & i will post the differences in the setups.
Then we can see a 2.4 6466 vs a 2.4 8374. I think it would be a good overlay since from 4k to 5k its similar but then mine shoots WAY UP.
But again apples to oranges, im more after just seeing what the low end difference is, since its so close eyeballing it. (MY AFR is f'ed in the log ill overlay though, since it was with the rusty gas tank).
