STMTuned 550hp 6466 stock motor
Congratulations to you and STM on the achievement!
I think we both share a very close setup and times; I am on a stock block as well but using F1/Full blown , tb, S3’s with an HTA86 on 31 psi/E85 and had my best run so far to be 10.9@135mph. My Exedy twin is getting tired and starting to experience lock outs occasionally as well. I am curious though, how much boost do you launch with? And what tires are u on? I am on 255’s Hancook ventus evo all season, and my best 60’ is 1.73 at 20 psi tire pressure, ~6 psi launch boost @ 6750rpm. I hope we both dip into the mid 10’s soon…lol Cheers!
I think we both share a very close setup and times; I am on a stock block as well but using F1/Full blown , tb, S3’s with an HTA86 on 31 psi/E85 and had my best run so far to be 10.9@135mph. My Exedy twin is getting tired and starting to experience lock outs occasionally as well. I am curious though, how much boost do you launch with? And what tires are u on? I am on 255’s Hancook ventus evo all season, and my best 60’ is 1.73 at 20 psi tire pressure, ~6 psi launch boost @ 6750rpm. I hope we both dip into the mid 10’s soon…lol Cheers!I don't know about boost in launch. I don't believe it's much. I think mostly just RPM launch around 7000. I have 26" QTP's
On my old setup I was able to do a 1.60 on my 255/40 falken rt615k around 16psi tire pressure I think 7psi of boost off of launch. I think your softer sidewall will help vs my street tire.
Clutch stuff pissed me off ! Lol
GL with your car !
Thanks man. I went through SRP Coatings. He happened to have one core on-hand which was this one and it was already shaved. I really like how clean and smooth looking it is. A local Evo guy here had BAD luck with Detective Coatings. They did a ****ty job on his cover and didn't even put the fittings back on the back and side of the cover. It turned into a real mess. But anyways, glad your car turned out badass. Love the FFM setups!
I thought it was twinscroll by the spool on the stock block...congrats you have a great powerband for SS. With a 1.5 sixty and better shifts with new clutch you could easily do low 10s the way you sit now.
I think the man behind the keyboard had a little to do with how the car runs haha. Eric's car has the power to pull off a 9.99 with a stock motor, which would be amazing. He's just gotta get seat time and drive it there.
shifting isnt the problem, once that launch gets down this sucker is gonna fly. eric can definitely drive the car
I could shift ok 1-3 but once it was time to go into 4th at high RPM it was just like NAH SON. Doesn't help I was NoLifting lol. I'm hoping it's the clutch and not trans but I'll get one if I have to next season
Thank you. That's my target weight eventually but it's going to be tough with a cage
I think car should be finished Friday or Saturday with the new parts.
Clutch was pretty much shot lol
