help as I can see the logs in a graph?
Old Mar 1, 2015 | 12:19 AM
4age1976's Avatar
hello, you can help me, that I have to do to see the information from various sensors in graphical form to analyze and locate if I have a problem in a sensor.
Old Mar 1, 2015 | 12:26 AM
4age1976's Avatar
High compression ratio engine turbo
hi , what are the reasons for the trend of using static compression releciones higher, 9.5 or higher
Old Mar 6, 2015 | 06:42 PM
Teal2nnr's Avatar
If you're running an AEM you can do to the sensors tab and check them there. I'm sure you can do the same with various other standalones as well.
Noize
Evo X Dyno Results
Mar 3, 2010 06:33 AM
KFC-AWD
Oct 28, 2005 08:25 AM
