Fp red went out so tried something new
Old Apr 24, 2016 | 08:49 AM
evo8vz's Avatar
car on c16 was at 520 with a red
2.3
276 kelford cams
3.5 ets fmic
s90 throttle 70mm
ported header
ported intake manifold
this was on pump
440 @ 25 psi
470 @ 26 psi more timing
482 @ 27 psi
bbk-c
Old Apr 25, 2016 | 08:51 AM
94AWDcoupe's Avatar
sooo. you miss the red?
Old Apr 25, 2016 | 08:57 AM
evo8vz's Avatar
hell no love this thing
red was a pos
its hitting 27-28 psi around 4200 rpm
Old Apr 25, 2016 | 08:58 AM
LetsGetThisDone's Avatar
Good gains per psi. Are you at the limit of the fuel now?
Don't be too hard on the red, I think it was hurt before it finally went, causing the poor performance..
Old Apr 25, 2016 | 09:21 AM
evo8vz's Avatar
yeah the red was hurting
i put q16 on it and it was sputtering not sure it was because i left the tank outside in the heat the barrell was swollen
car has a beefy fuel sistem fic 1650 high z/walbro 450 and fuel lab fpr i think it can handle 650 whp even on e85
went to the track it trapped 125 pump
hope to trap 135-140 once i get race gas in it
Old Apr 25, 2016 | 09:42 AM
Pal215's Avatar
I wouldn't consider that beefy until you see what other guys around here are running haha.
We're talking double pumper 450's w/ rewire and 6AN feed lines, drilled siphons, FIC2150's, fuel rails, and aftermarket FPR's.
Still, great numbers and i'm glad things worked out.
-pal215
Old Apr 25, 2016 | 09:55 AM
evo8vz's Avatar
-pal215
lol i was thinking about doing double
but my set up will never push it
i have 6an feed lines , fuel rail and fpr
just no double pumper
ran 1650 which cost me more than 2150 because i can rum ftw and q16
Old Apr 25, 2016 | 12:25 PM
Pal215's Avatar
Ah, i see!
Yeah, i thought about going double pumper as well, but i want to see how far i can go on a single 450.
-Pal215
Old Apr 25, 2016 | 11:08 PM
alpinaturbo's Avatar
Can you show us the RPM portion of the Dyno?
Its hard to understand how this -C spools.
Rare beast.
Where did you scope out a -C?
Thanks, had -B and loved it.
Old Apr 25, 2016 | 11:54 PM
evo8vz's Avatar
Rare beast.
would love to but tuner has the lap top
green pull around 2500
pinkish red ome 3000
peak tq is around 5200
i saw the graph for the 4bar and 27 psi was around 4200-4300 rpm
spool felt almost the same as the red with more power
check out my graph with the red
Jp7
Jan 2, 2010 06:00 AM
Iceman5
Aug 4, 2009 05:37 PM
dragon831
Jan 10, 2009 09:28 AM
Evasive EVO
Evo 'For Sale' Wheels / Tires
46
Oct 11, 2006 02:24 PM
