BBK-3B - my new favorite turbo
3 Attachment(s)
What's not to love about a turbo that makes 33 psi by 3800 rpm while making 530 whp at 7200 rpm on a 2.0L motor? In a kill-mode to kill-mode comparison, it kicked my HTA Green's butt everywhere, and it did it with a more restrictive intake than what I used with my HTA Green. The first plot is a comparison between my HTA Green and the BBK-3B for similar air temperatures. The second plot is the data log for the BBK-3B run. Peak exhaust manifold pressure is just under 50 psi whereas for the Green, peak exhaust manifold pressures at the end of a run were closer to 55 psi. The last data log shows a run for tamer BBK-3B boost settings. At this boost level, its probably making the same power as the HTA Green but doing it a much lower exhaust manifold pressure.
Definitely my new favorite street turbo. Red line = BBK-3B, Blue line = HTA Green https://www.evolutionm.net/forums/at...hmentid=221415 BBK-3B datalog for the VD run https://www.evolutionm.net/forums/at...hmentid=221416 Lower boost datalog for the BBK-3B https://www.evolutionm.net/forums/at...hmentid=221417 |
That's awesome I was going to look into this turbo!
What gear are these runs in?
It says 3rd on the vdr.
Originally Posted by GotWheelHop
(Post 11161308)
This is the turbo. I'm done.
Are you using a 2.5 compressor housing?
Still going to dyno in April?
Interesting.
What do the VD logs show in smoothing 6? |
1 Attachment(s)
Originally Posted by xXANCHORMONXx
(Post 11161331)
Originally Posted by droppinbottom
(Post 11161438)
Originally Posted by Benja
(Post 11161451)
Interesting.
What do the VD logs show in smoothing 6? https://www.evolutionm.net/forums/at...hmentid=221420 |
What actuator(HD, or stock IX)?
I could definitely use this on my life :D Great numbers
I guess you finally got it installed!
Nice. I think I am sticking with the 3B as well. Can't wait to se what it'll do on the 2.3. I think the market will be getting bigger for this turbo seeing as how it is +$300 for a MHI housing for a new green then add on a custom O2 housing/Downpipe..... Looks good! |
Originally Posted by sparky
(Post 11161688)
I was trying to figure out how the hell your getting 18º of timing at redline.....then I figured out it was E85, at least that's what your sig states :)
Please don't tell me this is on 93 ") |
