Evo 9 EFR7163/Origin Fabrication/Full Race/Pump 93
Mods:
Engine - Stock Block/IM/TB - ARP Studs - Tomei 270 Poncam Type-R - Spoolinup COP Turbo Kit and stuff - EFR 7163 Twinscroll - Turbosmart 23psi single port actuator - Full-Race Manifold - Origin Fabrication Inconel 625 downpipe - Origin Fabrication Wiggins charge piping/intake - Hypertune Intercooler - Tomei Ti catback - full 3" V-Band conversion Fueling/ECU - AEM Infinity 6 - Bosch 1050cc Injectors - AEM 320 fuel pump - MAC 3 Port solenoid Some pics of the car: https://c3.staticflickr.com/6/5628/2...c3d30325_c.jpgIMG_0283 copy by Matt Stephens, on Flickr https://c2.staticflickr.com/6/5589/3...65d1d1c3_c.jpgUntitled by Alex Whitacre, on Flickr Results: boost was a flat 270kpa (24.6psi) across the entire curve. https://c1.staticflickr.com/1/416/32...b040e153_c.jpgUntitled by Alex Whitacre, on Flickr |
Thanks for sharing! What was the temperature on the day of the tune?
It was between 75 and 80 degrees when the car was on the dyno iirc
Were you limiting torque to below 400 or was it just not capable of more?
Originally Posted by cerevo
(Post 11672285)
Was the pull done in 3rd or 4th gear?
(Post 11672396)
Idk what 30% load means...lol. Curious to see a boost plot in 3rd, on the street.
If I ever make a street log I'll post it up. Butt dyno says it feels the same as my 71hta at low rpm, but more power and a lot smoother.
You typically see much faster spool in 4th vs 3rd. That's why I'm asking.
(Post 11672554)
a VD log with boost in 3rd would be nice for comparison to the EFR kits we are building and other turbos... but, great build and nice results... enjoy.
We're going to be putting the car back on the dyno in a couple weeks to finish up the tune (now with fully functioning fuel pump) so I will be sure to have some pulls done in 3rd for you.
Why the switch to this setup from the 71hta? Doesn't appear to be that big of a difference?
Not degrading.... Just came across this as I am currently researching the 71hta upgrade. |
Originally Posted by dookgvr4
(Post 11675395)
