And better by fairly significant margin!
From ultimate power - to lower back pressure that enables running more aggressive (higher output) st lower boost and less ignition advance, for reliable performance on/off track. |
Originally Posted by dookgvr4
(Post 11675395)
Why the switch to this setup from the 71hta? Doesn't appear to be that big of a difference?
Not degrading.... Just came across this as I am currently researching the 71hta upgrade. The best way to describe it is that the car does not feel 'boosty'. The power comes on smoother and It feels more like a torquey NA motor as long as you are above ~3,000rpm. You just move your foot and it goes |
Definitely beautiful setup{thumbup}
How much boost are you running and at what rpm did you hit that target.
Not sure if I missed it somewhere. |
(Post 11675513)
1. Stock Motor 2. Pump Gas 3. Best powerband possible I think the 7163 is the best choice for my situation, given that you can afford moving away from stock frame turbos, which is really not that much of a $ jump nowadays.
Originally Posted by stimsoni
(Post 11676300)
Not sure if I missed it somewhere. We'll be getting the car back on the dyno soon to finish the tune (functioning fuel pump this time) and I will be sure to do a better job at getting info that time around. |
Originally Posted by awhit17
(Post 11676367)
Originally Posted by nemsin
(Post 11676453)
How much did it cost you all in?
But bolt-on to bolt-on stuff for the EFR isn't any more expensive...you just have to buy a tubular manifold. A 7163 + Turbosmart WGA is less than the cost of an FP ball bearing stock frame turbo. |
Thanks for posting up the info and amazingly built car. I too am contemplating the Fullrace EFR 7163 kit to replace my HTA 71. The graph is a little hard to read with the glare in the photo. Would you happen to have an electronic copy that you could upload possibly with boost info as well?
Originally Posted by Evol Knievo
(Post 11687313)
Very nice build.. The engine bay looks amazing.
Can you post a video of the dyno run ? or some street pulls ? |
As someone who hasn't even gotten my built 2.0 and HTA71 on, I am very looking forward to seeing what you get out of it.
Do you have plans to build it or run it til it pops? |
What kind of wheels?
Originally Posted by cerevo
(Post 11687562)
(Post 11687562)
Originally Posted by abk1024
(Post 11687583)
(Post 11687704)
No need to build the motor for an HTA 71. That's the beauty of the Evo 4G63 motor its way overbuilt so unless your trying to put 500 plus ponies to the pavement, spend your money on maintenance and sensible mods like brakes (not Wiggens couplers). :lol: J/K if I could afford it I would do it too.
Your engine bay does look pretty damn good. What type and colour have you used for the uicp and rocker cover.
