High Load Figures, 340!
2 Attachment(s)
My car is basically a stock evo 03 with a 9 turbo, and a perrin 3 inch full exhaust system.
redline AFRs go all the way to 10.4, doing 23psi as of now till i replace my actuator and tune for 25psi why are my load figures this high? is it normal? attached is my current rom and the newest log. |
That load is all messed up.
Can you try logging 1byte w/tephra? Hell, even Loadcalc may be more accurate. Also, that's pretty rich up top. |
Originally Posted by Project_Broke
(Post 11829106)
Can you try logging 1byte w/tephra? Hell, even Loadcalc may be more accurate. Also, that's pretty rich up top. but thing is, if the load readings were not accurate, why am i able to get rid of knock at those high loads on the table, I even rescaled the tables to accomodate that much load. |
MAF Scaling way off maybe?
I'm not at a computer with access to look at the tune. But no way in hell should you hit that much load with that much boost. |
Also, post this in the ecuflash section. You'll get better advice.
(Post 11829111)
is your load set up correctly on evoscan
maybe your factor is 1.8 or 2.0 have to see your rom and evoscan to determine this |
saw your rom
i would prob switch over to tephra and disable lean spool to get more consistant tune....and you might have a boost leak |
Originally Posted by Dakota Evo
(Post 11829811)
saw your rom
Post up in the tuning forum you might get better results. |
