High Load Figures, 340!
Old Jul 2, 2018 | 11:54 AM
TariqEvo's Avatar
My car is basically a stock evo 03 with a 9 turbo, and a perrin 3 inch full exhaust system.
redline AFRs go all the way to 10.4, doing 23psi as of now till i replace my actuator and tune for 25psi
why are my load figures this high? is it normal? attached is my current rom and the newest log.
File Type: csv
File Type: bin
Old Jul 2, 2018 | 12:57 PM
Project_Broke's Avatar
That load is all messed up.
Can you try logging 1byte w/tephra? Hell, even Loadcalc may be more accurate.
Also, that's pretty rich up top.
Old Jul 2, 2018 | 01:09 PM
TariqEvo's Avatar
Exclamation
About the richness, I will tune it properly after addressing the issue,
but thing is, if the load readings were not accurate, why am i able to get rid of knock at those high loads on the table, I even rescaled the tables to accomodate that much load.
Old Jul 2, 2018 | 01:15 PM
MAF Scaling way off maybe?
I'm not at a computer with access to look at the tune. But no way in hell should you hit that much load with that much boost.
Old Jul 2, 2018 | 01:23 PM
Also, post this in the ecuflash section. You'll get better advice.
Old Jul 2, 2018 | 01:47 PM
TariqEvo's Avatar
alright, I’ll do that when i get home, thanks a ton
Old Jul 7, 2018 | 08:10 PM
Dakota Evo's Avatar
is your load set up correctly on evoscan
maybe your factor is 1.8 or 2.0
have to see your rom and evoscan to determine this
Old Jul 7, 2018 | 08:14 PM
Dakota Evo's Avatar
saw your rom
i would prob switch over to tephra and disable lean spool to get more consistant tune....and you might have a boost leak
Old Jul 9, 2018 | 03:45 AM
TariqEvo's Avatar
Originally Posted by Dakota Evo
saw your rom
no boost leak at all, and i have not messed with evoscan definitions, mut 2byte load is defined correctly. the maf is really sending out those readings, could it be an issue with the maf sensor itself?
Old Jul 10, 2018 | 06:14 AM
2winscroll's Avatar
Post up in the tuning forum you might get better results.
Old Jul 10, 2018 | 06:16 AM
2winscroll's Avatar
TariqEvo
Jul 26, 2018 09:13 AM
TariqEvo
Mar 9, 2018 01:12 PM
badreligi0n
May 21, 2011 06:44 PM
