High Load Figures, 368!?
Old Jul 2, 2018 | 03:24 PM
TariqEvo's Avatar
Exclamation High Load Figures, 368!?
My car is basically a stock evo 03, mods are listed on my sign.
redline AFRs go all the way to 10.4, doing 23psi as of now till i replace my actuator and tune for 25psi
why are my load figures this high? is it normal? attached is my current rom and the newest log.
File Type: csv
File Type: bin
Old Jul 3, 2018 | 11:19 AM
Biggiesacks's Avatar
Boost leak test?
Old Jul 3, 2018 | 01:05 PM
LetsGetThisDone's Avatar
If the car is running a MAF, higher than expected load can indicate a boost leak.
Old Jul 3, 2018 | 01:16 PM
TariqEvo's Avatar
Nope, no boost leak, did a boost leak test, fixed all of them and it held boost properly
TariqEvo's Avatar
load is still that high
Old Jul 4, 2018 | 12:49 PM
foxbat's Avatar
Which load parameter are you logging, 1byte, 2byte?
I just opened your log file, you're logging load 2byte, it might be a definition issue, log load 1byte, it might yield realistic figures.
Old Jul 5, 2018 | 07:51 AM
TariqEvo's Avatar
i copied the mut table properly and defined properly.
also, if the readings were incorrect, i would be able to get rid of knock at like 330 load by reducing timing and adding fuel.
Old Jul 5, 2018 | 07:54 AM
TariqEvo's Avatar
I wouldnt* n yet I can
Old Jul 14, 2018 | 10:12 AM
mines5's Avatar
Tariq bhai this is definitely a rom issue.
Logged timing vs load is incorrect .
Check your TPS % also.
Switch to a well defined rom like 9653 or 9417 v7
Old Jul 15, 2018 | 01:51 PM
todd6027's Avatar
compare your maf scaling and maf compensation tables to stock ones
Old Jul 16, 2018 | 03:49 AM
TariqEvo's Avatar
I am currently on the process of switching to 96530706 V7.
but even logging with the tephramod brings such load figures, even with load 1 byte
Old Jul 16, 2018 | 03:50 AM
TariqEvo's Avatar
maf compesation are all the same.
however, the stock maf scaling makes my car stutter coz it runs very very rich, talking 8s by redline
Old Jul 25, 2018 | 04:14 PM
sandman121383's Avatar
What is your load factor? And also make sure the load factor in your rom matches evoscan.
Old Jul 26, 2018 | 09:08 AM
TariqEvo's Avatar
Update: fix
the issue was innacurate load readings, I tested this out by putting a fuel cut at 250load,
and voila, the car did not cut fuel even at said "368" load.
that was with tephramod load 1b load factor of 1.8 both in the rom and in evoscan as well.
so I decided to give 2byte load a go, and that was the fix apparently.
now it reads upto like 220, thought that is less than what the car is really doing.
but I found a way to trace the tables with the timing values.
Old Jul 26, 2018 | 09:13 AM
TariqEvo's Avatar
for some reason, my stock rom was not reading load at all and load 2 byte was bringing the high 360s as well.
TariqEvo
Jul 10, 2018 06:16 AM
TariqEvo
Mar 9, 2018 01:12 PM
blackevolution8
Sep 14, 2011 04:20 AM
RedLanEVO
Nov 30, 2008 06:29 PM
