stock speaker size
Old Aug 30, 2006 | 08:03 PM
Going 2B LE8's Avatar
i bought a set of 6.5's for the rears but they were still too small.
Old Aug 31, 2006 | 05:34 AM
evo4g63awd's Avatar
unless someone made the whole bigger, the speakers werent 6.5s
Old Aug 31, 2006 | 07:01 AM
LilJapnBoy's Avatar
Originally Posted by mitsuatb
6 1/2 and 6 3/4 will not fit without some sort of adapter.
The guy on ebay has good adapters, the acutal size seems to be a 7" european Din size.
Mitsuatb
I agree....unless the 9's speaker sizes changed from the 8's, standard 6.5" speakers will NOT fit.
I have 6.5" MB Quarts in the fronts and backs and they needed custom mounting to fit properly.
Old Sep 7, 2006 | 08:35 PM
scoob2evo's Avatar
are the speaker holes shallow or deep *for the magnets*?
Old Sep 7, 2006 | 08:39 PM
9GUY9's Avatar
The holes are pretty deep. I just put a set of Pioneer mid woffers in the doros and still have 2-3" between the door and the magnet. it would have to be a pretty deep speaker to not fit. Also like others mentioned I had to make a addapter ring to fit the 6.5" speaker in. The hole in the door is 6" The average 6.5" speaker has the mounting points on a 6" diameter circle.
Old Sep 7, 2006 | 08:50 PM
RicanEvo21's Avatar
yea i have a 10 w7 in my little mazda protege and it beats the **** out of my friends 12 T1 with my amp down then i turn it up and blew him out the water. oh by the way his is in a pathfinder so it should sound better. also should i keep my w7 and stick it in my evo once i get it or will it feel a lot slower because of the weight?
Old Sep 11, 2006 | 03:45 PM
ComA's Avatar
n/m
Old Sep 14, 2006 | 03:31 PM
diegoalunan's Avatar
what do you think about focal ks's? or v2's?.. and focal 11 inch subs, and focal amps.. ?..
i am thinking of installing or have it installed a whole focal package
Old Sep 15, 2006 | 06:19 AM
3SgteGuru's Avatar
I have a Related Question, What is the Tweeter size, If tweeters only come in one Size ok. I am an Audio noob.
Old Sep 15, 2006 | 09:22 AM
9GUY9's Avatar
Most tweeters are about the same size. Different brands are slightly different sizes, but most brands don't offer more than one size. Wiht a little work you should be able to fit any of them in the stock location.
Old Sep 18, 2006 | 01:27 AM
URBANRCR's Avatar
JL audio makes some of the best subs on the market . i dont have an Evo yet but i did install a system in my friends 8
2-alpine type R 6.5 up front
2-alpine type r 6.5 out back
powered by alpine f450
i just used alpines mounting bracket and they fit perfectly.
for the lows we did 1 JL audio 10"W7 powered by JL 1000/1
the system had a nice balance of lows and mids the highs where a lil weak but that was fine with us. if you are worried about weight and trunk space the 8"W7 is a nasty lil sub in a great package.
Old Sep 20, 2006 | 03:45 PM
Pd1's Avatar
Pd1
I did an entire Focal setup. You won't be disappointed.
Eclipse AVN6600 6.5" touch-screen navigation source unit
Speakers
Front: Focal 165KF (6.5"/1" separate)
Rear: Focal 165CV1 (6.5" coaxial)
Amplifier: Focal FP 5.500 (5ch 500W RMS)
Sub Woofer: Focal SB 21 V2 (11")
Old Sep 24, 2006 | 01:14 AM
ForgivenEvo's Avatar
Pioneer 6.75"/Oversized 6.5" speakers seem to fit fine. Check out their new component system.
Old Oct 3, 2006 | 08:42 PM
nashmage's Avatar
I have never uses jl but i can def. tell you that ma audio makes some amazing subs. I have had 2 12s for awhile and they are amazing. that and kicker i have had good luck with.
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Mar 15, 2014 12:23 AM
